Step 1, V2 can display more than 15 PSI...
02-22-2008, 07:17 PM | #1 |
153
Rep 5,780
This was done on the road, not simulated, so it is actual in-car logged data. I made some minor hardware changes to verify that the PROcede was able to see the higher numbers and it did. Unfortunately, the map is not made for the changes I made and was running pretty high boost, but that is being worked on.
As promised, more testing is being done and progress is being made. I hope to have more information over the weekend and be even closer to a solution for the overboost issues. |
02-22-2008, 07:53 PM | #3 |
اوليسيس
198
Rep 4,678
as impressive as always scalbert.
what exactly were the hardware changes you made?
02-22-2008, 08:28 PM | #4 |
153
Rep 5,780
As I mentioned, boost was not stable at this point and this was just a step. I would rather not disclose what was done until all is in order. We know someone would try this and end up blowing up their engine.
It should suffice to say for the time being that it wasn't much. |
02-22-2008, 09:45 PM | #5 |
153
Rep 5,780
I should note that after discussions; I will need to make more changes, not additional, just different. The new map along with the hardware changes should be in place this weekend and results will be supplied
02-22-2008, 09:48 PM | #6 | |
81
Rep 849
Should I trust the PROcede software or should I disable PROcede until the map is out?
08 E92 335xi Space Gray 6AT - PROcede V2 12.8 @ 111 mph
02-22-2008, 09:51 PM | #7 |
153
Rep 5,780
I would suggest getting an external gauge to verify. Some are fine without it but it is good just to be sure. In addition, I wouldn't try to up the UT values until you have that external gauge.
02-22-2008, 10:17 PM | #9 |
137
Rep 6,608
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote. |
02-22-2008, 10:46 PM | #10 |
136
Rep 1,954
Drives: 2020 X3M Competition
wtf are u guys talking about... i get 15.3-15.4 psi all day with 2.0.2 1-10 on 90-94% TQ... how many times do I have to post the same data log?
2020 F97 X3M Competition (current) - 2018 F80 M3 Competition - 2015 F82 M4 - 2012 E82 135i - 2010 E92 335i - 2007 E92 335i
02-23-2008, 07:51 AM | #11 |
153
Rep 5,780
02-23-2008, 07:52 AM | #12 |
153
Rep 5,780
02-23-2008, 07:59 AM | #13 | |
442
Rep 18,331
I bet you won't see anything higher than 15.2-15.3 in your logs even if you raised the UT!!! |
02-23-2008, 08:02 AM | #15 | |
19
Rep 604
So does it really matter? |
02-23-2008, 08:17 AM | #17 | |
153
Rep 5,780
But to further clarify, the overboost only occurs in warmer weather with higher UT settings and when romping on it in the 3000 - 4000 RPM range. So you can avoid it but it would be best to eliminate it. |
02-23-2008, 08:25 AM | #18 | |
19
Rep 604
As always,..appreciate your posts and input! |
02-23-2008, 08:28 AM | #19 | |
153
Rep 5,780
02-23-2008, 08:32 AM | #20 |
19
Rep 604
No. I'm not sure how to hook one up and dont know where to put it so it wouldn't look out of place in my car. I'm also new to this tuning stuff and trying to find an appropriate shop to install some of these mods I have in mind (Exhaust, IC, CAI). For now I'm 90% UT settings and completely stock otherwise.
02-23-2008, 08:45 AM | #21 | |
442
Rep 18,331
