Catless DP's & Limp Mode
02-22-2008, 07:01 PM | #1 |
81
Rep 849
So I had my UR catless DP's installed yesterday and they are absolutely insane. Turbo sound is simply nasty and exhaust note is very mean.
Only only problem tho. I get a limp mode ("Engine malfunction power reduced") everytime, about 15 minutes after starting the engine and it NEVER happes under boost, always just crusing or even at zero throttle. NOTE: I am not losing any power and the car runs perfectly normal. So it's kinda of a "fake" limp mode. Car still runs great! I already also have the Service Engine Soon light, which I don't care about. This happens in STOCK MODE and with PROcede enabled. Same thing. No difference. Any thoughts?
08 E92 335xi Space Gray 6AT - PROcede V2 12.8 @ 111 mph
02-22-2008, 07:05 PM | #2 |
136
Rep 1,954
Drives: 2020 X3M Competition
order the O2 simms from BMS at http://www.burgertuning.com/products.html. That should fix your CEL. I believe Vishnu will have a solution out shortly as well, and will simply include adding a wire to the PROcede harness, and changing the map.
2020 F97 X3M Competition (current) - 2018 F80 M3 Competition - 2015 F82 M4 - 2012 E82 135i - 2010 E92 335i - 2007 E92 335i
02-22-2008, 08:43 PM | #3 |
اوليسيس
198
Rep 4,678
can someone please explain what exactly those O2 sims are telling the engine that is going on?
i got a feeling someone is going to point me over to the other site.
02-22-2008, 08:44 PM | #4 | |
81
Rep 849
I'm trying to figure out if they are related.
02-22-2008, 09:42 PM | #6 |
63
Rep 1,743
02-22-2008, 09:49 PM | #7 |
81
Rep 849
Yeah, I was thinking about the O2 sim from Terry.
02-22-2008, 09:57 PM | #8 |
Rep 16
They are definitly related. The car is Limiting itself because it's reading that the vehicle is running very rich - that and it notices that you are running faster than an M series. Once you get the simms you shouldn't have an issue. Just curious, do you have an 08 or an 07? I just recently got the Riss Racing downpipes and they were telling me that the 08s were the ones having CEL issues.
02-22-2008, 11:32 PM | #9 | |
81
Rep 849
I have an 01/07 production. The car is running perfect tho, even with the fake "limp mode".
02-23-2008, 12:01 PM | #10 | |
32
Rep 793
i have an 06 built date. |
02-23-2008, 12:40 PM | #11 | |
ocasionally in crisis
52
Rep 2,358
once your bmw ecu program is updated with the latest one, you will most probably get cels with catless dps.
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
02-23-2008, 01:08 PM | #12 |
Moderator
133
Rep 6,775
Drives: TiAg E92 335
We need a mechanical o2 fix so we can leave catless downpipes in when going in for service.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
02-23-2008, 01:17 PM | #13 | |
Modder Raider
758
Rep 8,633
Drives: M3
I went to the catless DPs.
I ordered the O2 Simms from Terry and they work terrific. Quote:
The o2 Simms take the first sensor readings and the second sensor readings and tricks the ecu by adding "resistance" therefore tricking the ecu into thinking that there is a cat in place. There are actually multiple o2 simmulators. There isn't a "one solution" 02 simm because it depends on what else you are running...like is the car stock, or do you have an IC, etc. The first one that I got from Terry didn't work because I needed a stronger resistance since I was "free flowing" so well. The second one provided is working perfectly.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
