JL XD600/6 Vs XD700/5
11-13-2015, 01:11 PM | #1 |
45
Rep 225
Trying to figure out the best option here.
Current setup is: Hi-fi running a JL xd600/6 (ver1) Fronts are Morel Dotech Ovations Rear are BAVsound upgrade speakers. Under-seat Earthquake sws8 (4 ohm) the JL got wet and the rear channel is dead I also have a set of Jehnert xe 200's I will most likely replace the sws8's with the Jehnert's but I need to know if there is a benefit to going with the XD700/5 to drive them (mono) or should I just get another XD600/6 |
11-13-2015, 02:35 PM | #2 |
255
Rep 2,547
id get the helix pp82 dsp. power all the small speakers with it and bridge your remaining working channels on the 600/6 to power the underseats. youll improve staging and power will be huge (no Trump intended)!
11-13-2015, 02:59 PM | #3 |
1911
Rep 13,103
I think stereo under seats is better.
What the last guy said . It's probably worth getting the Jl fixed. |
11-13-2015, 03:33 PM | #4 |
300
Rep 3,969
Who needs rears? You're good with 4 channels.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
11-14-2015, 07:08 AM | #5 |
45
Rep 225
11-17-2015, 07:51 AM | #6 |
300
Rep 3,969
11-17-2015, 08:41 AM | #7 |
29
Rep 95
Website lists them at 130 watt nominal and 200 watt peak. Plays as low as 42Hz and up to 4,000Hz.
I like the idea of stacking the XD600 on the PP82DSP, but, are you overpaying for the PP82 since in this setup you will use it as a DSP-only because the XD600 packs more juice and will be used as an amp in this setup? |
11-17-2015, 09:15 AM | #8 | |
45
Rep 225
But now i'm intrigued....maybe I should just go with that as an all in one. But I really think the Subs and the Morel's will handle more than the PP82 puts out. And I have never been one to "love" DSP sound anyway. |
11-17-2015, 11:34 AM | #9 |
1911
Rep 13,103
Well you could go active on the doors with the 82dsp
Well you could go active on the doors with the 82dsp.
Yes adding and extra level of processing might add artifacts or color the sound in the earlier processors but I wonder how the helix's do ? |
11-17-2015, 06:44 PM | #10 | |
29
Rep 95
While the PP82, IMO, is a sound quality device due to the low wattage output, it still cranks and sounds great. I can turn the volume up all the way on the head unit, and also program the PP82DSP to increase all gains to the Jehnerts, and I know the Jehnerts can take a lot more power. What I don't know if how JL Audio's amp compares with the PP82. Is 55 watts from the PP82 = to 55 watts from the JL Audio amp or what? |
11-18-2015, 09:09 AM | #11 | |
107
Rep 471
https://www.minidsp.com/products/min...-box/c-dsp-6x8 As good as the helix box, and considerably cheaper (but not plug and play, and no amplification).
08 Montego Blue 135i Coupe // Sport Package // Custom E30 tune // str8shot bluetooth enabled ECA // Walboro 255 inline pump // BMS downpipes // VRSF 7" FMIC // Injen intake // Berk ceramic exhaust // OEM 550i clutch // MFactory single mass flywheel // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless brake lines // Turner 15mm spacers
11-21-2015, 06:10 AM | #12 |
255
Rep 2,547
str8 - do you know if the minidsp can take the balanced inputs from the hifi head unit?
11-21-2015, 09:03 PM | #13 |
Rep 145
I have the same question. If you look at some of the other minidsp alternatives they have the "three-wire" balanced option, while the C-DSP 6x8 has only a two-wire high level input option. It may still function properly, but I would check with the manufacturer first.
11-21-2015, 09:57 PM | #14 |
1911
Rep 13,103
How do you know its as good as the Helix
though it does seem to have most of the same features at first glance. |
11-25-2015, 09:17 AM | #16 |
45
Rep 225
Too many options to contemplate now....think I'll just try and get the JL fixed and drop the jenherts in.
