11-09-2015, 07:40 PM | #1 |
263
Rep 1,130
Drives: '16 340i AW MSport
340i Standard LED vs Full Adaptive LED
Are the Standard LED lights that come with the 340i static non-moving LED's? And do the full adaptive (lighting package) LED's move with the steering wheel? Is that the difference?
Do the Standard LED lights move at all? Anything else? |
11-09-2015, 07:44 PM | #2 | |
182
Rep 765
11-09-2015, 07:45 PM | #3 |
263
Rep 1,130
So are the standard LED's completely static? no movement, no swivels, no leveling?
Trying to decide if I really need it living in the Miami city, I'm not really going on curvy mountain roads at night, more like going south west east and north on flat lighted urban roads :P |
11-09-2015, 08:02 PM | #4 | |
45
Rep 114
2020 M340i
Previously - 2016 340i M Sport, 2013 335i M Sport, 2010 335i E92, 2006 E46 M3 vert |
11-09-2015, 08:07 PM | #5 |
4844
Rep 2,744
The standards do not angle left/right when turning the wheel. I had that feature on my last car, but I'd say it was only mildly helpful. But the lights do level vertically when starting the engine.
11-09-2015, 08:35 PM | #6 |
2253
Rep 3,622
The adaptive LEDs do follow curves as you steer, but the lighting package also comes with the auto high beams.
The standard LEDs are more than enough for me
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
11-09-2015, 11:00 PM | #7 |
263
Rep 1,130
11-09-2015, 11:07 PM | #8 |
2253
Rep 3,622
Correct.
11-10-2015, 10:52 AM | #9 |
Rep 10
The movement seen at startup is actually the auto leveling test procedure, after that auto leveling is always active to prevent blinding other drivers.
E28 518is 1988
E61 523i 2005 F30 328ixA 2014 F36 428ix GC (MT) 2016 |
11-10-2015, 11:11 AM | #10 |
2253
Rep 3,622
Yes I know I didn't read the question carefully enough
11-10-2015, 11:14 AM | #11 |
925
Rep 3,089
Am I wrong to think that VLD (variable light distribution) can be VO coded for the standard LEDs? I did it with my Xenons and the lights move horizontally based on my speed.
11-10-2015, 11:20 AM | #12 | |
2253
Rep 3,622
I could be wrong but that's what it looks like to me.
11-10-2015, 12:29 PM | #14 |
244
Rep 701
First i thought the adaptive LED (F36) is just left and right like the adaptive HID i had on my F30.
But I noticed there is difference in lightning output/range on different days. So I googled the LED headlight and there was a BMW PDF file that explained exactly what the adaptive LED does. Apparently there are 3 or 4 mode. Urban, City and some other ones. Basically based on the speed you are going, the car will get brighter and further at higher speed, if i recall correctly it was at 110km+. When you are driving in the city, the lights will aim lower and dimmer. I will try to find that doc. again. |
11-10-2015, 12:34 PM | #15 |
244
Rep 701
https://www.google.com/url?sa=t&rct=...06923889,d.cGc
it is a lot to read but very interesting if you have or planning to get the adaptive LED. I think the extra $800 is worth the additional cool things you get. Is it necessary? No. So is BMW. Also the high beam assist is really necessary if you drive alot in the dark areas. The LEDs are bright but it really does not shine very far compared to the ones with projectors. Last edited by oonowindoo; 11-10-2015 at 12:40 PM.. |
les anderson145.50 |
