11-08-2015, 10:50 PM | #1 |
83
Rep 224
Tire punctured but...
The tire pressure sensor never went on. Right when I parked my car it got punctured. I got out my car I heard the air hissing, went back in my car no indication of anything. Doesn't matter how it happened I'm filing a claim because it's property managements fault. So hours later I got back to my car started it up waited a few minutes and still nothing, drove it out my garage to meet with a tow service to put on my winter tire as a spare. My concern is that the TPI never came on any ideas to why?
Yes the car is equipped with the sensors, wheels are stock run flats on 19' so wtf even when I checked the car was showing all green. Thanks |
11-08-2015, 11:24 PM | #2 |
1488
Rep 2,020
I think they only work when the car is moving
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
11-08-2015, 11:27 PM | #3 | |
83
Rep 224
11-09-2015, 05:45 AM | #4 | ||
National Championship #17 and Counting!
793
Rep 1,508
If a reset doesn't fix the issue, may be a dealer trip.
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control |
11-09-2015, 06:14 AM | #5 |
301
Rep 718
The tire has to make a certain number of revolutions before the sensor can read it. If you changed the tires to your winter set and they are properly inflated, you won't get the previous low pressure fault because it is reading your new tires' pressure.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!) |
11-09-2015, 08:14 AM | #6 |
118
Rep 1,668
I do think that you have to run a short distance on the road before the TPMS activates and displays a message to you.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
11-09-2015, 04:16 PM | #7 | |
299
Rep 693
The warning only would have come up when changing to the winter tires if A) they are a different size tire with different PSI setting and/or B) The system was not manually rest. I am guessing from OPs statement; that this happened in the parking lot of an apartment or condo type area which is the likely cause of it not displaying since the distance from the puncture to your parking was not enough and even though air was hissing it likely did not lose enough air in that distance to trigger the alert. The system won't alert you for a 1PSI difference, normal pressure fluctuations are in the 4-5PSI range.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
11-09-2015, 06:17 PM | #8 |
83
Rep 224
Everytime I add air or change wheels i reset the tpi but they shouldn't even be on when i put my winter set because its not equipped? Only my oem wheels are.
When I got to my car later that day to move it the air was completely gone and was driven still nothing came on. Guess I'm taking it to the dealer lol |
11-10-2015, 08:34 AM | #9 |
118
Rep 1,668
Also your TPMS resets after one full driving cycle anyway so this step is not necessary.
This certainly sounds like you have a radio failure from one or more TPMS sensors so going to the dealership is the right solution.
11-10-2015, 02:57 PM | #11 |
404
Rep 962
If you have a Canadian car, there is no TPMS and instead we have RDC. It uses ABS speed sensors to identify a flat. Usually it works well at high speed and after some distance. Pulling out of the garage will not trigger it.
Also, because it's a differential system if all your tires are low on air it won't trigger. |
11-12-2015, 11:28 PM | #12 | |
446
Rep 1,369
