Another Alpina transmission flash to try
11-08-2015, 04:19 AM | #1 |
596
Rep 1,693
Hi guys,
I've found another Alpina B3 flash for somebody to try. I've got a lot of stuff on the go at the moment and I sold the laptop that worked with DCAN cables (My Mac's USB3 ports with whatever "power saving" features they use these days means a working DCAN cable drops in and out). The ZB number is 100% an earlier Alpina B3 flash. I have attached a screenshot of the latest kmm_ATSH.txt file showing the list of ZB numbers for the Alpina B3 models up to 2010 (You'll notice that 7603537 is the latest which is the most recently discovered Alpina flash before now). I have attached a zip file which contains a GKE215 folder with the files needed for this flash from SP Daten v32. Temporarily rename your GKE215 folder in C:\EC-APPS\NFS\DATA and put this one in its place. then flash the following ZB number using WinKFP: 7592076 Obviously, there's a good chance that it will be much the same as the others we've already tried but IMAGINE if it had significantly higher D mode shift points! You just never know till you try. I look forward to hearing some feedback on this one soon. Cheers, Brad https://drive.google.com/open?id=0Bw...nRmajVES1NKbnM https://drive.google.com/open?id=0Bw...nZ4YWhmZU9YX1k |
11-08-2015, 11:04 PM | #3 | |
135
Rep 1,075
11-09-2015, 03:28 PM | #4 |
Nerd
125
Rep 437
I'm interested as well!
2009 E92 335i Sport 6AT - Finished, sold
Transport for Ireland - LEAP Pass with TFI smartapp because cars are stupid expensive in Ireland |
11-09-2015, 03:58 PM | #5 |
18
Rep 268
The D mode is "TOO-economy" for me. Wish i could have D stock and DS alpina
Custom Wedge MHD 2+ Aggressive, AR Catless DP, ETS 5 FMIC, BMS DCI, BMS OCC, Berk Axleback, CF Diffuser, CP-E Chargepipe
11-09-2015, 04:02 PM | #6 |
596
Rep 1,693
Well try this flash then guys. It might do exactly that. If it's way better, the first tester will be always remembered. Think of the rep points!
11-09-2015, 05:39 PM | #7 |
245
Rep 1,236
Can it be loaded into the cars made in early 07?
2007 e90 335i: Single Turbo 700whp (Sold)
2009 e82 135i: Jb4 Only (Sold) 2010 e92 M3: Macht Schnell Intake, AA Pulley, IPE F1 Full Exhaust, 100% e85, RK Tunes Custom Tune (400whp) |
11-09-2015, 05:54 PM | #8 |
3441
Rep 79,211
In for results about D Mode. I wish I could leave D pretty much stock.
I'm not the most proficient coder otherwise I'd go out and do it now to see. |
11-10-2015, 02:45 AM | #10 |
48
Rep 263
What year cars are compatible for the TCU flash? I have a torque limit 4 problem and need a flashable TCU ASAP
UK
V8bait Tuned Built motor FBO 335i |
11-10-2015, 03:22 AM | #11 | ||
71
Rep 244
03-11-2016, 03:27 PM | #12 |
Ballin' out of control.
520
Rep 1,289
I can confirm that ZB 7592076 and the other four ZB numbers that Brad shared are in fact Alpina B3 TCU firmware variants.
In addition to these, I've found three other versions. 1 for the B3 with a N55 engine and 2 for the B3 with a N54 engine. I plan to hunt down the old SP Datens and begin trying the various flashes. Perhaps once I've had an opportunity to try them, I will post more details.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
