Super fast turn signal after coding angel eyes dimmimg
11-06-2015, 02:21 PM | #1 |
Rep 60
So I tried to disable the angel eyes dimming with this code PWM_RL_BL_1_FKT_SL - wert_01 (originally was wert_05) after coding that, I receive a rear left turn signal malfunction.. I tried changing it back to wert_05 but the turn signals still blinks super fast. All the lights do work, just the signal blinks fast. I do have the original settings backup file for the NFRM module, will I be able to copy everything from that and paste it into my current .MAN file so everything will go back to how it was originally?
I have a 2009 e92 335i with the LCI tail lights retrofitted. I'm not sure if this is causing the problem. |
11-07-2015, 07:23 AM | #2 | |
522
Rep 1,527
11-07-2015, 11:40 AM | #3 |
295
Rep 2,202
this!
Then find another value to code. Though the coding you tried may have worked on an 09 e90 may not be the same for your e92.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
11-07-2015, 12:50 PM | #4 |
Rep 60
I got it fixed! I guess I was using the wrong profile. I used "Expert Mode" that I downloaded somewhere from the net that probably didn't have manipulation enable or something. I noticed every time I code something, it would erase what I coded and put the values back to default. So I used the profile "EXPERT MAN" and everything works.
