11-04-2015, 11:51 AM | #1 |
925
Rep 3,089
Fuel level only alters right rear ride height?
I recently got coils and have been dialing in the ride height. I typically set the height with a 1/2 or 3/4 full tank of gas. Anyway, I've been monitoring how the ride height changes based on the amount of fuel I have and what I noticed is only the left rear height changes, all other wheels stayed the same. Does this seem odd? To me it looks like the gas tank is centered so I would expect the ride height to change for both rear wheels.
11-04-2015, 11:58 AM | #2 |
118
Rep 1,668
sounds to me like maybe your shock/coil over on the right might not have the same volume of compression that the others do. You are correct the vehicle has a good center of gravity with the tank in the middle. I would suspect suspension parts for sure.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
11-04-2015, 12:07 PM | #3 |
925
Rep 3,089
Thank you for the reply. Can you please explain your comment more? When I look at the ride height adjustment collar, it looks to be in the same position on both rear sides.
11-04-2015, 12:39 PM | #4 |
2810
Rep 5,316
Drives: G80 M3 6MT
I think he's saying its defective.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
11-04-2015, 12:45 PM | #5 |
925
Rep 3,089
11-04-2015, 01:17 PM | #6 | |
6659
Rep 15,858
If not, it could mean each corner has a different stressed condition. That can cause different heights across an axle at various loadings. HighlandPete |
11-04-2015, 02:07 PM | #7 | |
925
Rep 3,089
11-04-2015, 02:45 PM | #8 |
Pace Car Driver
1548
Rep 3,164
When doing suspension work, make sure the suspension is pre-loaded when tourquing down all the fasteners.
In other words, make sure the vehicle is on the ground and not hanging from a lift when fastening / torquing suspension components. Someone else did the install? |
11-04-2015, 02:46 PM | #9 |
925
Rep 3,089
OK I did a quick inspection of the rear suspension and based on a visual it looks like the left spring is at a slight angle while the right spring appears to be pretty close to vertical. Based on this, maybe one of the springs is not seated properly. I will remove the rear tire and check it out.
11-04-2015, 02:48 PM | #10 | |
925
Rep 3,089
The problem is, how do I get to the various components to tighten if the car is on the ground? I guess I would need to put the car on ramps?
11-04-2015, 02:49 PM | #11 |
Pace Car Driver
1548
Rep 3,164
Fudge it, take it back to them. Problem solved.
11-04-2015, 03:09 PM | #12 | |
6659
Rep 15,858
Fixed height springs can show up incorrect tightening with odd ride heights, adjustable springs allow hiding of the fitting error. |
11-05-2015, 08:37 AM | #13 | |
118
Rep 1,668
11-05-2015, 08:40 AM | #14 |
118
Rep 1,668
But what is not hidable (to the car at least) is the tension factor of the incorrectly installed or defective spring. It may have more tension on the spring to force a particular ride height but the torsion that is produced is also higher meaning less travel and likely weird ride patterns. essentially it is like running spring rubbers or adding a round on a track bar which will slightly compress the springs.
11-05-2015, 08:57 AM | #15 |
87
Rep 191
Drives: '17 340i X-Drive M Sport EBII
I noticed on my 435i, in the secret menu, it shows 15.5l for I believe the right tank and 39.5l for the left tank, however, the left tank with the most drops faster. I may have gotten the left and right tank mixed up, or I'm misunderstanding it, but idt it'll make that much of a difference
I assume it's just defective but worth pointing out just in case |
11-05-2015, 09:28 AM | #16 | |
925
Rep 3,089
11-05-2015, 01:46 PM | #18 |
925
Rep 3,089
hmm...so it may make sense that my left side is higher than the right??
11-06-2015, 10:46 AM | #19 |
87
Rep 191
Idk if it'll have that much of a difference though, passengers would have a much larger effect, idt it's that sensitive
