10-27-2015, 02:17 PM | #1 |
12
Rep 101
Old Timer Needs Help
After a happy decade plus of my E39 (530i), I am in the market for a used F30 automatic.
The question I have relates to what sports mode does to the handling of the car. Does it affect the ride height in the luxury and s.e models. Alternatively should I hold for an M Sport model. I have read around the subject but the information often seems contradictory. Thanks in advance of any replies |
10-27-2015, 02:37 PM | #2 | |
219
Rep 377
Hope this helped, and that it was accurate lol once again, speaking form F32 experience. |
10-27-2015, 07:12 PM | #3 | |
3572
Rep 10,352
The settings also adjust the shift points of the AT and DSC settings
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
10-27-2015, 07:42 PM | #4 |
12
Rep 101
Thanks for the quick replies as I am currently considering two cars. To sum up when you engage sports mode , on luxury /se models , it tightens up the steering and throttle but doesn't change the damper settings.
Thanks again. |
10-27-2015, 09:01 PM | #5 |
404
Rep 962
The sport mode will only tighten the suspension if you have Dynamic Handling Package. Otherwise, it only adjusts steering, throttle and transmission behaviour. Then ride height never changes, only the shock rebound does.
My last car was also an E39 . Overall, the F30 is about the same size and as a package it is better overall. Some things, like soundproofing and fit and finish were better on the E39 though. |
10-28-2015, 08:00 AM | #6 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
What exactly is an "s.e" model? Are you referring to modern line or base? No matter which line/model you have, sport mode won't affect ride height nor will it affect the suspension unless you have the Dynamic Handling Package. I have it on my M-Sport 335i and I highly recommend it unless you're just looking for a more comfy ride.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
10-28-2015, 05:55 PM | #8 |
87
Rep 191
Drives: '17 340i X-Drive M Sport EBII
I'm not too sure but does the year of the car make a difference? Like 2012 model vs 2014?
