10-27-2015, 09:57 AM | #1 |
44
Rep 136
I was driving in comfort mode with the shifter on D and I needed to accelerate quickly so I increased throttle and the car accelerated quickly but it got stuck on 7000 rpm and speed stopped increasing :
I didn't notice at first because I was focusing on the road and the stupid people I had to move away from to avoid any accidents once I noticed the car noise I decreased speed and everything was back to normal for some reason the car didn't shift to the next gear and stayed on really high rpm, but why? : (2014 335i m sport) |
10-27-2015, 10:31 AM | #2 |
87
Rep 191
Drives: '17 340i X-Drive M Sport EBII
Maybe the car thought u were going to accelerate some more but if it went to 7k and stayed there, it seems it was in manual, I'm not sure about standard but if u have the SAT with paddles, it doesn't up shift for u
10-27-2015, 10:40 AM | #3 |
44
Rep 136
it wasn't in manual or anything, everything was on the normal setting. it was weird that it stayed on the same gear and didn't up shift , I don't know if I should be worried that something is wrong with the transmission.
10-27-2015, 10:48 AM | #4 |
772
Rep 1,502
If the circumstances were indeed exactly as you claim then yes, something is wrong with your transmission.
However I find it odd that you don't report the throttle cutting out, which the engine would do in a potential overrev situtation, if you were still trying accelerate when the transmission hit 7000 rpm. Normally what you'd see if you were aggressively applying gas is the engine hitting whatever the max rpm is, throttle cutting out, revs falling, throttle coming back, hitting max rpm again, rinse and repeat. Commonly called bouncing off the rev limiter. In your case you are saying you hit 7k rpm and the engine and transmission simply sat there. So I'm not 100% on board with your description of what happened. |
10-27-2015, 11:00 AM | #5 |
Rep 45
Drives: 2013 328i, 2014 328i
This could happen if the transmission went into 7th gear when you accelerated. It would stay in that gear until you relaxed throttle pressure. The reason is because the transmission is not rated to carry full engine torque in top gear. To protect the gears from overloading, the transmission controller won't shift up to the top gear if the engine torque exceeds safe limits.
10-27-2015, 11:01 AM | #6 | |
44
Rep 136
I didn't get any message in the idrive screen and the temperature was normal, I will add this to the list of things to be checked on her next appointment which is November |
10-27-2015, 11:07 AM | #7 | |
44
Rep 136
that was my first thought , that it was on last gear but I don't think it was because the speed wasn't high enough to need the last gear for speeding but I don't know : |
10-27-2015, 11:24 AM | #8 | |
118
Rep 1,668
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
10-27-2015, 12:46 PM | #10 | ||
6659
Rep 15,858
The other possibility I'm aware of, is related to what the OP does say his next action was after hitting 7k. Quote:
I recall when first finding the feature on my E39 540i, thought it was a fault until I read up on it. We can suppress automatic upshifts it we want to, or the 'box will hang on to the high revs if we lift off at the wrong time. HighlandPete |
10-27-2015, 01:03 PM | #11 | |
3575
Rep 10,352
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
10-27-2015, 01:12 PM | #12 | |
231
Rep 982
I've had a different but similar pretty dumb situation. In the previous gen X5 of my dad I would rest my hand on the stick kinda similar to in the manual. Apparently you can push it into neutral just like that lol car started revving while just traveling 60mph and didn't even have an idea that I did that until it happened again a few days later Just needed a really small nudge.. Perhaps the same with the paddles? |
10-27-2015, 01:57 PM | #14 | |
772
Rep 1,502
As others have said, it was mostly likely approaching redline from hard acceleration followed by a sudden lift off the gas. |
10-27-2015, 02:17 PM | #15 | |
219
Rep 377
10-28-2015, 06:30 PM | #16 | |
87
Rep 191
10-28-2015, 07:21 PM | #17 | |
44
Rep 136
10-28-2015, 07:26 PM | #18 | |
3179
Rep 2,577
Lemania 2320
10-28-2015, 07:28 PM | #19 | |||
44
Rep 136
but I don't really know why it happened , it didn't happen again today, though I noticed something I could be wrong but when I drive in sport mode then change back to comfort after a while , it shows that I'm in comfort mode but it feels that I'm in sport mode, but could be just a feeling idk |
10-29-2015, 06:29 AM | #20 | |
21
Rep 61
10-29-2015, 06:49 AM | #21 |
36
Rep 433
Yes, this is what happens - I also frequently find myself having to floor the car to get away from stupid people, and I just use the upshift paddle to manually get back to a cruising gear quicker!
