One last go at Santa Pod
10-25-2015, 06:04 PM | #1 |
283
Rep 2,343
Hi guys,
well I've been to Santa Pod about 10 times this year now. I only planned to go once but each time I kept thinking I could do better and I had to go back to try. My first attempts at the start of the year showed me I didn't know how the heck to launch the car and saw me getting 14 seconds. Later I managed to figure a way to move off by holding the car on the brake and engaging the accelerator just a bit to engage the clutch of the DCT. Brake boosting isn't possible. I managed to trap over 110 mph before adding meth injection and then managed just under 12.5 seconds ET with the meth at 117 mph. Later I started using a back end flash to better use meth injection and ethanol added to my fuel but I always found that the flash never quite worked with the DCT transmission. The shifts felt off and laggy. The car really lurched. It was like changing gear in a manual and not quite fully getting off the clutch. So for this reason I got a custom flash done by Trebila. Some people use Wedge or Spxx or other. Anyway in the recent tests at home the shifts felt really good and the car felt fast so I had to hit the strip again. I went running 25% ethanol in the fuel tank and meth+water at 60:40 to suppress some timing pulls I was getting on cylinder 2. I've tried changing the spark plug and coil pack but I can't get rid of this issue. It's probably carbon build up in the cylinder, a bad injector or false knock. Anyway timing was pretty food on my runs with just cylinder 2 a little behind. Running a 50 meth adder I managed to break my previous best trap speed of 117.95mph with 118.06mph but my time was a poor 12.9 secs due to a near 2.5 sec 60ft time I was happy that the car had potential. However my second run was 13 seconds and 117mph. The next 4 of 5 runs also saw 2.4 sec 60ft times killing my ETs. Then on my last run of the day I nailed a good 60ft time of 2.1410 secs. I had the car on the absolute limit of grip without spinning too much and cruised to a 12.2179sec@120.59 mph. That's M4 trap speed right there. I'm sure if I had better tyres I could break into 11's. Anyway very chuffed and probably going to leave Santa Pod until next year now. But you never know Video, time slip, log to follow...
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
10-25-2015, 06:37 PM | #2 |
283
Rep 2,343
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) Last edited by AWSAWS; 10-25-2015 at 09:04 PM.. |
10-26-2015, 04:04 AM | #3 |
12
Rep 66
That's a great time! I'm planning on going this Sunday for the last rwyb of the year. I've not run the 335i before so it'll be interesting
James
2009 E92 335i Titanium Silver
JB4 G5, BMS/MHD Race flash, Pure Stage 2 DD, RB Turbo inlets & outets, BMS Meth kit (60/40), Wagner Downpipes & Intercooler, CPE Charge Pipe, Ramair DCI, DCT Paddles, Alpina F30 big brake kit, ST/KW variant 1 coilovers, M3 ARB and control arms |
10-26-2015, 05:09 AM | #4 | |
283
Rep 2,343
p.s. I always felt my car had more than the 117 it was achieving. Firstly because of the aweful traction off the line and secondly because my DCT was never working quite right. The service I had a few months ago also helped. My brother beat me to the line twice in those videos but my ETs are lower each time.
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) Last edited by AWSAWS; 10-26-2015 at 05:17 AM.. |
10-26-2015, 05:24 AM | #5 |
28
Rep 308
Hey Jack,
Trebila definitely has the car dialled into perform with your DCT gearbox, well worth the investment! Consistently over 120 that's getting serious Like you say, stick some drag radials on and you will be in the 11’s ! Well Done bud I will have to practice brake boost for next time!
Jb4 with Trebila BEF,vargas stage 2+ turbos, vrsf dp's, vrsf cp with tial bov, vrfs 7" fmic, EOS PI with BMS PI controller, RB Inlets and Outlets, bms meth kit, BMS DCI, miltek cat back, bms occ,3.5 tmap, ngk 5992 plugs, HSD coilovers, M3 rear subframe, diff, drive shafts , suspension and brakes.
10-26-2015, 05:28 AM | #6 | |
283
Rep 2,343
the guys in the states get some seriously good times off the line with the brake boosting in 2nd on steptronic. There's an enourmous bonfire there soon. You should take the kids
10-26-2015, 05:45 AM | #7 |
28
Rep 308
Just looking at the log! You're pushing that LPFP I see you are short shifting and not a full throttle in 1st and 2nd too much wheel spin? Love to see what you could do with some VP109 and some 275 nitto nt05r on the rear!
Or is it time to invest in a stage 1 pump???? Might be a visit to Shrewsbury again
10-26-2015, 06:01 AM | #8 |
28
Rep 308
Yes, I saw that...unfortunately we have other plans...it may have been a different story if the inlets would have arrived and David had worked his magic
10-26-2015, 07:04 AM | #9 |
16
Rep 212
Drives: E92 335i & E93 335i DCT
I think you're getting into territory where you desperately need a LSD!
It'll transform your launch and first 60ft.
E93 335i DCT M-Sport
Turbo Dynamics Stage 2+ Hybrid turbos - Evolve FMIC - VRSF catless DPs - Remus Race exhaust - Injen CAI - VRSF CP & HKS BOV - Quaife LSD - Gladen 120.4 DSP kit - CIC to NBT Upgrade - JB4 G5 w/ race flash - Ohlins R&T suspension - next mod: go faster stripe. |
10-26-2015, 07:30 AM | #10 |
283
Rep 2,343
TBH I don't think I'd bother with a LSD. Better tyres would be a more economical way to go. I think I'll get some Toyo R888 next year.
I had to really modulate the throttle in 1st and 2nd. That's how the low 60ft time was achieved. Before each run I did a small wheel spin to heat the tyres. In 1st gear I can just go full throttle and the wheels spin immediately, the car barely moving. I didn't hold it against the brake as I don't want to wear them any faster. On the lpfp I think maybe the flash just isn't quite able to handle rapid changes in demand for fueling, with ethanol and meth and water injecttion and rapidly varying trims. I may play with the fuel scalar a bit.(See the trims are 30's and 20's in 1st and 2nd, but 0 in 4th and 5th!) I also don't know if standard pumps cope well with low levels. Do they have the venturi to help maintain flow when acceleration may throw the fuel to the back? Anyway an upgrade will happen at some time. For me this puts the run into perspective
10-26-2015, 07:59 AM | #12 |
283
Rep 2,343
haha yeah
He was a nice chap. I had a chat with him. His back window was full of cuddly toys so I wouldn't say he's too hard core.
10-27-2015, 06:11 AM | #13 |
39
Rep 234
Definitely no LSD is needed. Good times but you can definitely do better.
As you say, work on that 60ft and get your self some better tyres. No LSD was required recently for an N54 to break into the 10s... so Tyres it is. You should definitely not be wasting any time launching in 1st. Why not just limit boost in second so you can push it to redline? Or use the JB4 to limit it in lower rpms and maintain a higher boost in higher rpms in second gear? |
10-27-2015, 06:20 AM | #14 | |
283
Rep 2,343
10-27-2015, 06:33 AM | #15 | |
39
Rep 234
DCT is unknown stuff to me.Lower than stock is crazy haha. The Xdrive e92s in the states launch like crazy |
10-27-2015, 08:24 AM | #16 | |
283
Rep 2,343
The Xdives are great of the line but the added weight of the 4WD means they suffer on the trap speed.
10-27-2015, 04:29 PM | #18 |
400
Rep 5,623
Congrats. 120mph plus is an excellent time. Its very hard to get a good 60ft time.
Making me wanna go back this Sunday, but i'm going Rockingham next week |
10-27-2015, 08:00 PM | #19 |
283
Rep 2,343
10-28-2015, 06:46 AM | #20 | |
400
Rep 5,623
Might go to a full track day in the Spring when the weather is better. Really want to go Bedford. |
10-29-2015, 07:09 AM | #21 | |
283
Rep 2,343
Just think how this guy in the BMW felt! "I'll just go out and take it easy. What's the worst that could happen, right!?" Hope he had cover
10-29-2015, 12:15 PM | #22 |
400
Rep 5,623
I'll definitely get insurance for a full track day. But for 30mins on a taster session? Rockingham said they have never had a single incident on a taster.
But when i go to a full day then insurance is definitely something i'll be getting. As like you say, even if i'm driving ok, it could be someone else driving like an idiot. |
