10-25-2015, 05:50 AM | #1 |
15
Rep 50
N55 surely is one hell of an engine
i was having some late night snack with my friends and on my way back to home on freeway when a mustang and an accord (i know right?) were racing side by side so i followed them.
The 2 in front were making a lot of noise for sure but werent showing much progress so i just thought what the hell and turned my car into a sports mode. I just went passed them like how bmw passes hondas and fords... later on the mustang came back this time with a 370 on the side, but the story didnt change much. i mean okay, accord, maybe is nothing but mustang and 370? this is one hell of a credit bmw should be getting. i am impressed by how the engine goes. |
10-25-2015, 08:42 AM | #3 |
BMW Fanatic
331
Rep 1,076
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
10-25-2015, 09:39 AM | #5 |
2070
Rep 2,639
10-25-2015, 09:42 AM | #6 |
770
Rep 1,270
Can you elaborate on your guarantee?
10-25-2015, 09:49 AM | #7 |
2070
Rep 2,639
10-25-2015, 09:56 AM | #8 |
770
Rep 1,270
So just from the perspective of what produces more HP/TQ from the factory?
10-25-2015, 09:59 AM | #9 |
2070
Rep 2,639
10-25-2015, 10:03 AM | #10 |
8245
Rep 16,088
+1. It's not a totally fair comparison, but my 240HP rated N20 is better than my 270HP rated Altima with the exception of off the line, where the displacement and lighter weight (by 600 pounds) of the Nissan gives it a slight edge. In the all important 50 to 80MPH passing acceleration the N20 beats the Altima.
10-25-2015, 11:18 AM | #11 |
1913
Rep 2,210
Drives: '17 jackrabbit on crystal meth
Was it a 5.0 Coyote driven Mustang? If so, it has a ~100 HP advantage (everyone knows the N55 produces more than 300 HP) over the 435 and despite it being 200 lbs heavier, should pull on the 435 during a highway roll.
As for the Datsun and its antiquated VQ37, yeah....it's toast.
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
10-25-2015, 11:35 AM | #12 |
87
Rep 191
Drives: '17 340i X-Drive M Sport EBII
I believe the N55 actually makes about 325 hp and 335 lbs ft and it has a great power band
10-25-2015, 06:50 PM | #13 | |
446
Rep 1,370
An engine is basically an air pump with lots of little holes drilled in it. At low RPMs the holes are too big and high RPMs the holes too small. In practical terms this means that at a certain RPM range, the engine hits peak torque. Before the range, torque still increases, but after, it falls. If the torque band can be widened then you have a car that can keep pulling for a longer period of time. As a made up example, let's say you have a car with a 4000 RPM band (with less power) and one with a 2500 RPM band (and more power). Now lets say they both hit peak torque at 1500RPM, both cars are increasing their power and still accelerating. But now the car with the 2500 RPM band hits 4000 RPM and has no more gears. Max torque starts to fall off despite having more power (i.e. the power is being wasted). The car with the wider band can still keep pouring on the torque until 6500 RPM. Now, 6 sp vs 8 sp transmission. That car with the 8 speed is going to have 2 more gears to stay in the power band. Combine that with the fact that a high compression engine (i.e. turbo) does better with slower burning fuel (i.e. high octane) and another advantage is added. More gears, wider band, it makes a big difference. Of course, if you have a 100HP turbo vs a 300 HP NA, well, no engine trick is going fix that. But you have a 230 hp vs 300 hp engine, yeah, you can get better performance throwing every engine trick there is at the problem. |
10-25-2015, 07:40 PM | #14 |
2253
Rep 3,622
I would rather have almost any other v6 engine on the market than the VQ37. Nissan/Infiniti has really lost its appeal to me
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
10-25-2015, 07:58 PM | #15 | |
1435
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
10-25-2015, 09:09 PM | #16 | ||
2253
Rep 3,622
