10-24-2015, 11:01 AM | #1 |
528
Rep 226
Will it fit?
That's what she said hahah all jokes aside.
I feel like the M2 will looks much better with wider rubber. I'm thinking of swapping the rear 265s up front and installing 295s in the rear. The 10" rear wheels will have no problem holding 295s. I'm just wondering if the 265s will rub up front. What's everyone's thoughts on this idea? |
10-24-2015, 11:19 AM | #2 | |
231
Rep 334
jnoyes35.00 |
10-24-2015, 11:41 AM | #3 |
7905
Rep 11,785
It's probably possible. I would try immediately on delivery. The 1m rear 10l wide wheel and tire will fit up front. Most people don't try and run square with OEM wheels likely due to cost.
On the oem wheels 265 runs slightly and 255 does not run at all so most people do 255. For track I run apex arc 8 18x 10 all around on my 1m. 285/35/18 fits all four corners for track. A 315/35/18 fits on The rear with 18x10.5 and even wider is possible. Hope this carries over on the '2. All these turbo cars nee d more rubber I'm |
10-24-2015, 03:42 PM | #4 |
1901
Rep 5,678
Given the M2 uses the same wheels as the M4, I suspect if a wheel/tire combo fits the M4 it will fit the M2. What you suggest works on the M4.
Having said that, no one knows yet so it is purely speculation.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
10-25-2015, 11:34 AM | #5 |
5243
Rep 5,874
In order to keep the balance, I would consider moving the 265s to the front and put 275/35s on the rear. They'll be closeer in diameter that way too. Yeah you can't rotate front to rear but that doesn't matter to me at least. 295/30s might be too much grip in the rear but maybe that's needed.
10-25-2015, 09:56 PM | #6 |
652
Rep 1,922
Drives: 2011 e91
Even though a 295 will fit on the factory 10", it will look grossly bulgy.
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
10-26-2015, 06:11 PM | #7 |
528
Rep 226
10-27-2015, 12:18 AM | #8 |
Dinosaur supervisor
3027
Rep 4,214
10-27-2015, 12:28 PM | #9 |
198
Rep 146
Here is a popular thread over on the M4 forums detailing tire options for stock wheels. Lots of good info already compiled there.
http://f80.bimmerpost.com/forums/sho....php?t=1089535 |
12-31-2015, 04:16 PM | #10 |
1566
Rep 29,202
But the M2 has slightly narrower tires though, 245/35/19 and 265/35/19 vs the 255/275 on the M3/M4.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
12-31-2015, 06:04 PM | #11 |
652
Rep 1,922
Drives: 2011 e91
BMW says the larger M4 rubber won't fit. I call bullshit. They probably reduced the width to slow the car around the ring, otherwise, it'd be too close to the M4 in terms of performance.
2011 E91
01-01-2016, 01:18 PM | #12 | |
1901
Rep 5,678
01-01-2016, 01:39 PM | #13 | |
Dinosaur supervisor
3027
Rep 4,214
Fitting wider tires will be no issue at all, probably not M3/M4 offsets but adding 8-10 mm should be doable when looking at the photos. This is of course just my amateur opinion from looking at way to many Long Beach Blue M2's. |
