Where to start with this type of boost leak?
10-23-2015, 07:21 PM | #1 |
90
Rep 115
I have a pretty obvious boost leak, but after days of research I haven't seen logs of one quite like this yet. Running Roc Euro DCI, ER chargepipe, and MHD. 65k miles, 91 oct, Southern California.
Note that as I flash to more aggressive maps, the boost stays closer to target. Theres a 1-2 psi loss at all times across the board, but note that above 5k the stock map has a larger boost loss than stage 1 and a significantly larger boost loss than stage 1+. These big top end boost drops are very noticeable when driving. What type of leak would allow this to happen? A chargepipe/intercooler connection leak doesn't logically seem like it would be so reactive to a change in maps, and all connections are sturdy. Vac lines or could it be something even more major? If anyone has experienced anything like this and has some input that would be awesome. Currently nursing this and have an oil filter housing gasket to replace so hopefully she'll be running strong again in a couple weeks. These are the logs (easily repeatable with same results; none of these were a one-time test). Stock: http://datazap.me/u/bdefiori/stock?log=0&data=2-4-21 MHD Stg 1: http://datazap.me/u/bdefiori/er-cp-0?log=0&data=2-4-21 MHD Stg 1+: http://datazap.me/u/bdefiori/er-1-plus?log=0&data=21 http://datazap.me/u/bdefiori/sept-5?log=0&data=2-4-21 |
10-24-2015, 10:21 AM | #3 |
187
Rep 337
I'm facing a similar issue.
WGDC is very high, but boost is well below target in the low RPM's. I eventually hit 19 PSI, but it's not reaching that until around 3,800rpm. It could be a multitude of problems including hose clamps, pipes, boost solenoid, etc. My car is currently at my Indy's for a vacuum test to pinpoint my leak. |
10-24-2015, 10:35 AM | #4 |
171
Rep 311
Boost leak testing is tricky on these cars. I recommend doing a true boost leak test from the intercooler inlet forward so you can actually put some decent pressure in the system and check all the major connections from the head to the intercooler inlet.
Then test from the Inlets to the intercooler inlet , this will not allow near as high pressure as you will blow the Inlets off the compressor housings. Start there, bit it may also be a solenoid issue, bad turbo(s), split vacuum hose, tune setting. Wastegate actually interference or adjustment out. Just have to start testing and narrow it down to find the culprit. |
10-24-2015, 03:42 PM | #5 |
Joint Chiefs of Staff
4920
Rep 115,999
The most likely place for a boost leak is the throttle body connection on CP and the lower CP connection to the FMIC. Check those first.
Smoke test would be the next step. Mike |
12-29-2015, 06:50 PM | #6 |
90
Rep 115
Update: Target boost still not attained. Car was actually overboosting for a day (20 psi peak) after catless DP install and then went back to underboosting the next day, so the turbos aren't cooked or anything.
Upgrade/test list: All vacuum lines redone Wastegates tested w/ vacuum (can hear both close) DV's tested w/ pressure Solenoids tested at idle (10-15") - when divided by 2 enough to close both wastegates Vacuum canisters showing standard vacuum Pressurized system soapy water bubbles test ER chargepipe uninstalled/reinstalled FMIC connections rechecked Here's another log from today w/ Ken's v6 beta: http://datazap.me/u/bdefiori/god-dam...=0&data=2-3-20 Getting really pissed off about not being able to find the culprit . Car still feels plenty fast, but my ego as a part-time amateur mechanic is destroyed haha. If anyone has been through the wringer with this like me and found some obscure solution that I can try, please let me know! Last edited by bpdef29; 12-29-2015 at 07:16 PM.. |
12-29-2015, 09:12 PM | #7 | |
654
Rep 946
12-29-2015, 09:30 PM | #8 |
187
Rep 337
My Indy and I rigged up a $10 smoker and found small leaks from half a dozen spots. These leaks were too small to throw a 30FF, but enough to cause underboost.
Clamps were reclamped, orings and clips were repostioned, etc. |
12-30-2015, 11:36 AM | #9 | |
90
Rep 115
12-30-2015, 08:57 PM | #10 |
90
Rep 115
Smoke test showed nothing . Great DIY though Yournamehere. Unplugged a DV and got it to blow rings with the pump haha. I've officially done every possible test. Time to flash stage 2 since its winter with weather in the 50s and just enjoy the car for what it is...
Edit: Stage 2 log somehow looks good! Closer to target that I've been in any log I've taken, regardless of the stage! http://datazap.me/u/bdefiori/stage-2?log=0&data=2-3-18 Last edited by bpdef29; 12-30-2015 at 10:02 PM.. |
