10-22-2015, 08:50 AM | #1 |
MBurg
63
Rep 236
Front fogs, M-Sport
I was in Italy last week and saw a 2 series M-Sport with front fog lights - which is different from US configuration where M Sport trim does not include front fogs. Assuming that the wiring harness is there and it is only a matter of the front cowl 'panel' and light housing, etc, does anyone have a way for ordering european parts?
10-22-2015, 09:00 AM | #2 |
2690
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
I believe all the 2ers outside of the U.S and Canada that aren't the M235i will have fog lights as standard with the M-Sport kit. You can find the fog lights on eBay but you will need to search for the mesh surround
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust |
10-22-2015, 11:56 AM | #3 |
45
Rep 459
The 228i also loses the fogs in M Sport guise (in the US, the market referenced).
10-22-2015, 01:24 PM | #5 |
106
Rep 855
If you do not already have the lighting package they are very useful. They double the amount of light on the road in front of you. The amount of light the Halogens toss off without them on is not very bright.
10-23-2015, 01:16 AM | #6 |
2690
Rep 1,977
I do use the foglights here in Australia when I'm driving at night during winter, especially if I'm doing a trip away from the city areas, there can be a bit of fog and it's always good to see whats on the road in front of you.
I really like the foglights on the 2er, here's mine next to 2 m235is
10-23-2015, 06:00 AM | #7 | |
52
Rep 321
I've got the halogens on my m-sport 228i. I think they're pretty good for halogens. |
10-23-2015, 08:37 AM | #9 |
1539
Rep 3,332
Fog lights really shouldn't be used to offset low output from the headlights because they point outward and will be very bright to oncoming drivers.
Keep in mind the M235 receives aux radiators in each of the side vents. So on an M235 retrofitting the fog lights will be cutting off airflow. On a 228, you would need to purchase the external parts as well as the internal switch and likely the wiring harness. I can not imagine BMW leaving the wiring in for something they've removed.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
10-23-2015, 10:58 AM | #10 | |
1753
Rep 2,942
Graf 2: If you look at the U.S.-spec 228i M Sport's lower side grilles closely, you'll note that the actual pass-through area of the intake only takes up about half the surface area of the grille. Same goes for the M235. There's plenty of room for fogs, as the AUS-spec M Sport in the pic shows.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> Last edited by Viffermike; 10-23-2015 at 12:18 PM.. |
10-23-2015, 12:09 PM | #11 | |
106
Rep 855
10-23-2015, 12:25 PM | #12 |
70
Rep 229
Never saw the point of fog lights. I was always taught to look as far up the road as practical, not a few feet in front of the car where the fog lights shine their light. Simply put, they don't put the light where I am looking.
10-23-2015, 12:28 PM | #13 |
106
Rep 855
They just add to the light from your Halogens. Very noticeable difference in the brightest of the light in front you. You can't look further than your regular lamp beams anyway. Having Fog Lights just makes them brighter, does not add to the distance of your regular beam.
10-24-2015, 05:14 AM | #14 |
228i - 2015-03
13
Rep 66
Fog lights are designed to be used ... in fog condition !
This is why they are placed as closed to the ground as possible to light the road below the fog. Normaly with fog ligths on, one shuts the regular lights down because they only light the fog, like a wall in front of the driver |
10-24-2015, 07:59 AM | #16 | |
1753
Rep 2,942
Check out the websites of PIAA, Cibie or Hella for a primer.
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
10-24-2015, 04:11 PM | #18 | |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
BTW, fog lights are yellow BC that color (about 25K) cuts thru better than white. |
10-25-2015, 04:23 PM | #19 | |
1436
Rep 2,526
Drives: 2011 328i Wagon
Read this for the technical explanation: http://www.danielsternlighting.com/t...fog_lamps.html
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
10-25-2015, 04:50 PM | #20 |
4695
Rep 6,046
I am surprised at the general mis-understanding of fog lamps. They are not intended to be used with, or to supplement headlamps. They are placed low to get under the fog, as fog generally starts a foot or two off the ground. Normal headlamp illumination will bounce off fog, back at the driver, and deteriorate vision for drivers in fog. The fog lamp illumination goes as far as possible under the fog to provide as much light as possible for the roadway, and driving speeds should be adjusted accordingly. They are not intended to enhance design, appearance, or look cool. In some states, it is illegal to illuminate them simultaneously with headlamps, and some vehicles are wired to prevent using both together.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
10-26-2015, 09:28 AM | #21 | |
45
Rep 459
