10-20-2015, 02:03 PM | #1 |
19
Rep 68
Dinan Stage 2 EWG/MPPK vs EWG only
I do not have the MPPK and recently had the Dinan Stage 2 installed...
1) Any chance of my dealer installing the Dinantronics Stage 2 for EWG AND MPPK instead of Stage 2 for EWG only? Part numbers D440-1641-ST2 and D440-1639-ST2, respectively. 2) And if they did, would it matter? Thanks!
2012 E93 M3 Convertible - BMW Individual - Azurite Black Metallic/Rust Brown - MPE - Dinan Software and Intake
10-20-2015, 02:34 PM | #2 |
Gettin It Figured Out
1820
Rep 2,669
I'd hold off on MPPK, save your money and go straight to Dinantronics S4 (if you plan on staying the Dinantronics route).
10-20-2015, 02:38 PM | #3 |
19
Rep 68
Thanks, ronanz but that's not the issue. I do not have, nor do I want, MPPK...
I think they installed the wrong variant of the software and I want to know if it matters... Below is the response I got from Dinan: "For record keeping purposes and long term health of the car it would probably be better to go back to the dealer and have the box reprogrammed to the correct software but it is not absolutely necessary. The car will run fine with the MPPK variant of software you have on there now though. Difference being it is running a bit more boost then we would like for that setup (hence the long term health comment) but it will function with no running problems. You would not be achieving the same gains as what is reported for that software either as the base numbers are lower not having MPPK."
10-20-2015, 04:43 PM | #4 |
207
Rep 242
If Dinan says it's fine then I wouldn't worry about it. More boost is better anyway... you're backed by the full Dinan warranty. Just in case, hang on to that email.
10-20-2015, 11:00 PM | #5 |
19
Rep 68
@chutak , I agree... We surmised that HP was probably accurate between the two tunes (382-384) and torque was somewhere between (417-455)...
Looks like it's time to hit the dyno
10-21-2015, 05:56 AM | #6 |
Moon Parasite
655
Rep 1,336
If you have a question about which version of software was installed I would take it back to them and have them verify which was done, you paid for it and the job should be done correctly. If they did install the wrong version they should install the correct software for no charge.
Although someone there at Dinan is telling you it should "probably" be OK but also uses terms like "for the long term health of the car" you should get the correct version, to me that's like my doctor telling me I should only worry about taking amphetamines if I'm concerned about my long term health, in the short term I'm going to feel great. "We" all like to talk about how Dinan engineers their products for the best performance and reliability. If you're not using it as it was designed and what it was designed for that seems to defeat the purpose. My opinion, and it's only that, is if you have a question about it get it verified as to what the situation is and if it's not correct get them to make it that way. Again that's what you paid them for. Not to make a potential mistake that "could affect the long term health of the car"
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
10-21-2015, 01:01 PM | #7 |
19
Rep 68
CIWS Well said. You make some very good points. I'll be sure to head down to the dealership soon.
Appreciate the reply.
10-22-2015, 08:40 PM | #8 |
2680
Rep 3,406
"Don't worry about it...you're fine. But you can go and get it corrected if you want. But it's not necessary." is basically Dinan's way of saying "There's really no difference between the two, but we put two versions out there to make people think there is. You don't have to waste your time, but if it's going to help you sleep better at night, feel free to take it in."
10-29-2015, 05:39 PM | #9 | |
497
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
In my experience you will also have issues if your dealer makes a dumb mistake and puts the wrong wastegate type DPT on your car. First dealer I went to ordered and installed my S1 for my car, couple months later started running into problems and went to another dealer to check on them and upgrade to S2. Turns out the initial installer dealer put an EWG unit+harness on my MWG car, how they did that I have no idea but they got me a new unit and harness from Dinan CA and reinstalled for just the cost of the software upgrade to S2.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
10-30-2015, 10:27 AM | #11 |
497
Rep 902
Since there are only 2 stages for the N55 I assume he means stage 2 and that was a typo.
10-30-2015, 10:53 AM | #12 | |
1820
Rep 2,669
