N54 FBO with METH map 3 UK
10-20-2015, 10:13 AM | #1 |
Rep 50
Hi Guys
As above i have had my car a short while now which has got the mods in my signature When it first got done the dyno showed 474bhp and 575lbs of torque but the tuner advised this was running low boost as the car kept misfiring. Ive since changed all spark plugs, all coil packs and there has been no misfiring and the car is running very smooth question is the car is apparently capable of over 500bhp with the mods i have which the tuner has apparently done but its not been proven yet! We are due to go on another dyno day soon and i want to make sure i can get the best figures possible Whats the best way to set up the JB4 running meth for my mods? I have attached some pictures of how it is set up at the moment should anything be changed? Cheers
-PREV 540BHP M6, NOW E93 335i N54 2008 DCT! Engine mods - FBO BMS DCI, BMS Catless DPs, Wagner FMIC, CPS charge pipe with Tial BOV, JB4 G5, BMS full meth kit 500bhp 575lbs torque! Cosmetics - Satin pearl white wrap, Gloss black spoiler & rear diffuser,tinted windows & rear lights,Black kidney grills & Eyelids,H8C angel eys, Ice white bulbs, Red Dakota leather, Neon lit footwells, BMW logo puddle lights, HD cameras front & bk
10-20-2015, 12:34 PM | #2 |
Rep 50
Now with Logs
Hi Guys just done some logs in the car from changing the meth additive from 35, 40, 50 and finally up to 60 (the tuner had it on 40)
Can someone that knows what they are looking for tell me which would be the best setting and if there are any other settings i should change? 60 definitely felt like the car pulled the strongest Attached are all picture logs and all excel logs Cheers
10-20-2015, 06:32 PM | #3 |
226
Rep 2,387
Well the best way to start would be load up the latest JB4 firmware. It's 31.7 by now I think and yours is 30.2? Read up on it over on N54tech. Be sure to pay attention to the new parameter settings.
Then if you don't already, some sort of backend flash, either BMS or BMS-MHD RACE flash. After all that run Map 3 as usual and step into meth add with plenty of logging to check. http://n54tech.com/forums/showthread.php?t=10605 http://n54tech.com/forums/showthread.php?t=20563 |
