10-18-2015, 09:52 AM | #1 |
925
Rep 3,089
1.5"/1.25" drop front/rear...how screwed up will my alignment be?
So I finally dropped my car on coils. The drop is 1.5"/1.25" front/rear. I am getting my alignment this wed. I am curious how out of whack my alignment will be? I know we have no camber adjustment in the front and limited adjustment in the rear. Will I be able to get my car back into spec with this drop? I just don't want to chew through tires.
10-19-2015, 04:21 PM | #2 |
230
Rep 1,554
Yes should be no problem to dial it back to factory specs. You can actually adjust rear camber up to -3 degrees. You wont need to, but just saying that is a lot. Car looks great and I love my Kws as well. Best ride I have ever had being lowered.
10-19-2015, 05:42 PM | #3 |
925
Rep 3,089
Thank you. Lets see how the alignment goes on Wed.
I read your threads a lot before deciding on the KWs. Your car served as an inspiration.
10-23-2015, 02:21 PM | #4 | |
230
Rep 1,554
Thank you. I love the KWs and everyone that rides in it is shocked how low I am and how it rides so smooth. Today is Friday so how did your alignment go? |
10-23-2015, 03:50 PM | #5 | |
925
Rep 3,089
Here is a pic of my alignment. Everything looks to be in spec aside from the right front camber which can't be adjusted. Hopefully its not too bad. What do you think?
10-27-2015, 07:38 PM | #7 |
925
Rep 3,089
Any tire shop can do alignment. Its easy.
10-27-2015, 07:40 PM | #9 |
925
Rep 3,089
They should have access to the proper alignment specs.
11-04-2015, 09:39 PM | #10 |
11
Rep 74
During alignment after installing DINAN springs and Bilstein B8 struts & shocks, my F32 435i xDrive had slightly too much negative camber on the left front. My mechanic says it's not likely due to lowering, and while it would be desirable to be in spec, it shouldn't be much of an issue save some possible wear on the inner edge of the tire. It's only like 0.3 degree out of spec. Bummer that camber is not adjustable. He called the dealer to see if they had any suggestions and they simply began advising that he begin swapping parts... That's not gonna happen.
Any concern that your screenshot shows an "E90/E91 (2006 - 2012) Sedan/Touring (Wagon)?"
2014 435i xDrive MSport / Black Sapphire Metallic / Black Dakota Leather / MPPK / 6MT / 19" / M Sport Brakes / DINAN Springs / Bilstein B8 / Technology Package / Premium Package / Cold Weather Package / Driver Assist / HK Sound
11-11-2015, 08:55 PM | #13 | |
925
Rep 3,089
EDIT...got this from another thread. Its for a 335 but I believe the 4 series have the same specs. According to this it looks like I am within spec for everything. Last edited by tboooe; 11-12-2015 at 09:04 AM.. |
