2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Here you go, Curt 11367 hitch on M235
      10-11-2015, 05:49 AM   #1
horsepower_and_hounds
1836
Drives: BMW
Ok folks, here it is. The Curt 11367 3/4 series hitch installed on the M235. I have accomplished this even retaining the underside heat shield. These pics are with the MPE and M diffuser.
One casualty suffered, the front r/h cover tab broke when I pulled on the cover. The l/h popped right out, the r/h just broke off.
Enjoy the show.....
1-Up rack pic's uploaded & with bike mounted
Appreciate 12
      10-11-2015, 01:16 PM   #2
G8rGrl
569
Drives: Like a Boss
Awesome! Thank you for posting.
      10-11-2015, 07:17 PM   #3
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
Thanks for being the first person to bite the bullet.
It does look like it sits much higher on the F2x vs the F3x - was hoping it would be a no trimming affair like the F30.
Either way, great to know it fits and for ~$150 it's a much nicer solution than the roof rack!
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      10-12-2015, 04:29 AM   #4
1836
Drives: BMW
I agree...but the part that suck is i sold my 1-up hitch race 2 months ago since I had given up on a hitch. Now I gots to buy a new one
      10-13-2015, 10:16 AM   #5
voukephalas
Drives: m235xi Cabriolet
Thanks for being the first! How long did it take you and what tools were needed? Also, what did you use to cut the diffuser? Post updates when you get the bikes on there!
      10-13-2015, 06:47 PM   #6
1836
Drives: BMW
It took awhile but I tend to be slow and through.... torque, loctite, etc. Have a big racing back ground. Used the standard tools they recommend with a few I prefer. I used a hacksaw, flat & round file, exacto knife, dremel to do the diffuser. Small tin snips for the heat shield
      10-16-2015, 01:21 PM   #7
voukephalas
How would this have been different if you installed the diffuser after the hitch? I'm thinking getting the performance diffuser as well as the hitch and not sure what to do first (if I get the diffuser at all)
      10-16-2015, 08:08 PM   #8
1836
Drives: BMW
Thread updated with rack pics
      10-19-2015, 03:34 PM   #9
gmorrell
Drives: 2016 m235i xdrive convertible
Thanks for posting this.
It looks to me like the hitch goes behind the steel bumper, and pushes it back about 1/4". Does this cause any trouble with the fit of the plastic fender/bumper cover? Does it still line up correctly with other body panels?
It looks like you had to trim a little off of the back end of the heat shield. Did you have to trim anything else that is not shown in the photos?
My car is a 2016 M235i XDrive convertible. I wonder if there is any difference in the back end of my car compared to yours that would cause this hitch to not fit.
Sorry to see the broken tab. That kind of thing drives me nuts.
Thanks for taking the plunge. It's very helpful and encouraging to people like me looking for a hitch for this car.
      10-21-2015, 07:06 PM   #10
1836
Drives: BMW
I had to enlarge the mounting bolt holes in the hitch slightly for it to slide on and yes I had to trim the heat shield. they tell you you don't need it on the other series 3/4 but I wanted to put it back on so I spent the time cutting and test fitting till it went. On the bumper cover it rides hard on the corners since the hitch pushed the hard under bumper out but there is like a 1/4-3/8 gap there before you start so it just moves that far out and fills the gap
      10-26-2015, 03:04 PM   #11
gmorrell
Hi, just wondering if you have had any problems since installing your hitch. I saw in a different forum that someone with a 1 series car had problems with the muffler rattling against their hitch when the exhaust system heated up, wondering if you have experienced this.
      10-26-2015, 07:19 PM   #12
1836
Drives: BMW
I had that problem with my 1 series..that was probably me. Zero issues so far with this installation
      11-02-2015, 04:26 AM   #13
1836
Drives: BMW
All pics from tear down to bike carried have been uploaded for future interest
      11-07-2015, 07:35 AM   #14
Larry7995
11
Drives: 2015 M235i xdrive
The Hitch Corner in Littleton CO is going to install the same one on my M235 on Veterans Day. Wish me luck!
      11-07-2015, 08:36 AM   #15
1836
Drives: BMW
None needed....it will work
      11-11-2015, 07:19 PM   #16
Larry7995
11
You are correct, The Hitch Corner didn't have any trouble at all with the install. They do great work! And my Thule bike rack plugs in and folds up without touching the finish. Thanks again! It likely wouldn't have happened until I showed this thread to the owner a couple weeks ago. He looked it over and said OK we can do that. Hitch + labor were $287.
      11-11-2015, 07:52 PM   #17
1836
Drives: BMW
I can sent you my address if your feeling generous abour your savings
All seriousness congrats. It was worth the risk to me, it was too much of a PITA to shove my bike in the back 3+ times a week
      01-24-2016, 07:39 PM   #18
cth6
cth6's Avatar
Drives: '16 M235i
Anyone try this with PDC yet? Just wondering if there will be enough space one for the PDC wiring.
      01-24-2016, 08:39 PM   #19
NEUE02
NEUE02's Avatar
267
Drives: M235i
For some reason I hadn't seen this thread before. I don't have any need to install a hitch on my M235i but I just wanted to acknowledge what a fantastic job you did. Looks perfectly stealth! Nice work!
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S
      01-31-2016, 11:22 AM   #20
cth6
cth6's Avatar
Drives: '16 M235i
Hitch is on order. Will see if PDC gets in the way.
      02-03-2016, 05:38 PM   #21
Tito44
Tito44's Avatar
14
Drives: 2015 BMW M235XI
cth6 Let us know how it goes!
I need to put a hitch on my car to trailer my motorcycle around.
Anyone doing this with the regular M Sport Bumper as opposed to the Diffuser?
      02-04-2016, 08:38 PM   #22
cth6
cth6's Avatar
Drives: '16 M235i
Box arrived today, so it looks like I have a project this weekend after I mow the lawn.
Tags
bmw 2 series tow hitch
Search this Thread:
Advanced Search
2addicts
