10-09-2015, 07:12 PM | #1 |
303
Rep 1,134
I was thinking of getting a downpipe but I don't want to deal with the smell, however, I know going the catted way is going to be expensive. Is there a catless downpipe that y'all recommend that doesn't smell as bad as others? How about a catted downpipe?
Also, I don't want to run a tune so I was thinking of doing the BMS canflap to delete codes. Is there a cheaper way to simply delete the cel that the dp will throw? I just mainly want the dp for sound and not performance. |
10-09-2015, 07:18 PM | #2 |
181
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
Any catless dp will be the same. Pipe is pipe. Just paying for a name IMO for a catless pipe. They will all smell. In terms of defeating the CEL you can get an o2 spacer but idk how long that will last you. Your best bet will be the can flap module I believe. I'm not too familiar with it but I've heard it's the way to go to get rid of CEL without a tune. I have a Enzo Performance tune on my car and it's definitely worth it. The increase in power is amazing. Paired with the catless dp and your golden.
10-09-2015, 07:21 PM | #3 | |
303
Rep 1,134
10-09-2015, 08:32 PM | #5 | |
Pace Car Driver
1548
Rep 3,164
It will smell, no way around it. |
10-09-2015, 08:42 PM | #6 | ||
303
Rep 1,134
10-09-2015, 09:02 PM | #7 |
Pace Car Driver
1548
Rep 3,164
10-09-2015, 09:47 PM | #8 |
303
Rep 1,134
Yeah but I think I'd rather play it safe and have it on instead of hoping it doesn't bust and then being stuck on the side of the road one day. Either way I have no need for a tune. Simply looking for an increase in sound and a way to delete the cel without a tune.
10-09-2015, 10:26 PM | #9 |
353
Rep 939
Everyone needs a tune, they just don't know it yet.
10-09-2015, 11:55 PM | #10 | |
303
Rep 1,134
All I simply want is advice on a catted or catless downpipe that doesn't smell. So I now know catless down pipes are going to smell no matter what, so if someone who has a catted downpipe wants to chime in on how bad the smell is, please let me know. Is it going to be less than a catless downpipe? |
10-10-2015, 08:14 AM | #11 |
151
Rep 179
Downpipes
Okay, well just helping you with wording, a "cat- less" downpipe is simply called a downpipe...other than that theres a catalytic converter or a high-flow catalytic converter. Getting a high-flow cat would help reduce the exhaust smell...but you won't make the same numbers or sound as a downpipe so it remains kinda pointless in your case if you're not trying to spend money. Go to a local muffler shop and see if they have a custom high-flow cat for you. That would be your cheapest route.
10-10-2015, 09:47 AM | #12 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
OP: Actually, a downpipe can be just that with or without a catalytic converter. There are downpipes with high-flow catalytic converters and those with the catalyst removed altogether. A "catted" downpipe would have a catalytic converter with less restriction and likely be slightly larger in diameter as well. There's a secondary catalytic converter further down the exhaust system where the downpipe connects to the center section. The purpose of the "cat" as it's called is to burn any unburned hydrocarbons in the exhaust stream. If you remove or reduce the amount of catalyst material, the exhaust will have more of an odor than it would with both cats intact. So a catted downpipe will give you more flow, but there'll be a bit more smell (stand behind a '60's musclecar with the engine running and you'll understand what it's like). The early catalytic converter cars from the mid-1970s had a really horrible rotten-egg smell back when gasoline had lots of sulfur in it, and there was a distinct "burnt" smell as well. Low-sulfur gasoline and better catalyst materials have reduced that significantly, but any time you modify or remove one or both of the catalysts, it's going to smell quite a bit. Depending on where you live, you may or may not pass inspection, specifically if they use a tailpipe sniffer instead of just checking the OBDII output for a "ready" status. I recall that there is also a $10K fine for "tampering with federally-mandated emissions equipment", although I've not heard of anyone or any shop getting nailed for that.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
10-10-2015, 10:29 AM | #14 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
If you want a catless downpipe without the smell lol it's not gonna happen. There is no converter hence it will stink like a skunk.
Even Hiflow catted ones have a bit of a smell because they have a 200cel design for high flow instead of 800. It's the price you gotta pay for sound and power. Not sure what else to tell ya.
FBO-PS1 and stuff
10-10-2015, 10:43 AM | #15 |
22
Rep 88
The smell with a cat-less down-pipe on this car really isn't that bad; I rarely notice it except when I'm backing the car into the garage.
'22 M240i Portimao/Cognac
(Sold) '14 335i Estoril/BK • M Sport • Prem/Tech Pkg • M Perf INTR • VMR V710FF • Shifteck DP (Sold) '95 M3 Avus/Dove • PSS9 • Vorschlag Camber Plates • 3.46 Torsen Diff • etc. |
10-10-2015, 10:50 AM | #16 | |
303
Rep 1,134
Thanks for the help everyone |
10-10-2015, 10:54 AM | #17 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
10-10-2015, 10:55 AM | #18 |
243
Rep 447
I've got Fabspeed catted downpipe and there is no extra smell that I can perceive from this mod. The power gains aren't that far off from catless; so far no CEL either, and I believe they recently updated the catted version to further avoid CEL. But if extra power and no extra smell is what you want, then this would be a good option from personal experience.
'15 M235xi | BSM/Oyster/Aluminum | Black Kidneys | RW Carbon Mirror Caps | 40% tint
10-10-2015, 11:12 AM | #19 | |
22
Rep 88
10-10-2015, 12:44 PM | #20 | ||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
10-12-2015, 08:55 AM | #21 |
181
Rep 396
I actually have the VRSF dp on my car. Just got it installed a couple weeks ago and the quality is spot on. You wont be disappointed in the quality of the VRSF plus it has lifetime warranty. I posted a thread not too long ago and how it sounds after I installed it.
10-12-2015, 02:53 PM | #22 | |
BimmerPost Supporting Vendor
24199
Rep 190,807
Most smell issues i see are because the downpipes are cheap and do not fit 100%
