10-07-2015, 04:04 PM | #1 |
41
Rep 144
Coding
Hi I'm a new F20 owner with Xenons!!
I'm blessed as it has nearly every option on it but it needs some coding like my 5 series did. All listed below I coded on my 5 series and I'm hoping to do the same on the one series. Minus maybe the DVD in motion as I'm not sure if this pro nav plays DVDs. Ill list what I want to code and the if you can let me know how to do any the module and values I need to put in (sorry rusty with coding) and ill do them this weekend. Mirrors fold on engine off Mirrors unfold on engine on Mirror down in reverse Horn bleep for unlock and lock radio and screen off when drivers door opens Change the sensitivity of the light sensor for Xenon headlights so they don't come on all the time in the day Start stop memory so if I turn it off its off Enable playing of videos of USB stick or DVD in motion with pro nav. Possibly auto high beam always active when headlights are Any other things anyone thinks of please let me know. It has most options apart from leather seats. Thanks in advance |
10-08-2015, 03:18 AM | #2 |
Rep 18
You might want to see this. I'm still gaining confidence to start coding on my care. I'm afraid I will screw it up...
http://f30.bimmerpost.com/forums/sho....php?t=1020138 |
02-05-2016, 05:03 AM | #4 |
Rep 70
01-08-2017, 05:31 AM | #5 |
Rep 1
I have a f20 as well, CIC still, but a lot of the coding from the f30's sheet seemed to be helpful, and othre stuff, like launch control, i had to look a lil bit more, but was able to find it through f30 steps. Also, i'm from brazil so we don't get a lot of easy info around here ahahah
01-16-2017, 09:24 PM | #6 |
Rep 6
01-17-2017, 09:20 PM | #7 | |
2374
Rep 8,364
F20 / F21 / F22, F3x, & F8x use the same ECU's. So, F22 sheet or F30 are good places to start. Other options are BMW Coding Database. |
330DE9013.00 |
08-03-2017, 04:49 PM | #8 |
Rep 11
Esys problem
Hi anyone here knows about Esys coding?
I have a problem with a 2013 F20 116D, canīt read some of the CAF files Can anyone help? View post on imgur.com |
08-03-2017, 04:55 PM | #9 | |
2374
Rep 8,364
08-03-2017, 05:02 PM | #10 |
Rep 11
PSDZ ???? What is that?
Found it. Itīs a Dir on the program that has some files.
I have this one Extracted from ISTA-P version 3.58.3.003 Is it the latest one? Last edited by Ze_Pedro; 08-03-2017 at 05:17 PM.. Reason: * |
08-03-2017, 05:06 PM | #11 |
2374
Rep 8,364
Coding: (No Request) Latest Software Links
01-14-2019, 04:07 PM | #12 |
Rep 1
Double codes
Hi!
Yesterday I downloaded the ESYS VM and when I connect my F20 I can choose between to raws both no direct: F020_18_07_549_v_004_003_000 F020_18_11_531_v_004_002_000 Why they are two? And which one I have to choose? |
01-14-2019, 09:03 PM | #13 |
2374
Rep 8,364
Some releases offer two. Select latest and you should not have issues.
01-21-2019, 05:41 AM | #14 |
Rep 2
iOS or Android?
Hello Guys!
This will be my first post, please bare with me if i have not shared it in the right place.... I just wanted to know which platform (Android or iOS) to purchase the full version and install BimmerCode on? Are there any differences within the app on each platform? Noticeable glitches or anything as such? Thank You!! |
01-21-2019, 08:03 AM | #15 | ||
1040
Rep 1,341
Hello,
It's not the device but the car you code. It must be the same minding only connectivity issues which appear inexistent (I don't use it myself, just at a glance). If any functionality differences (errors) happen the developer should just fix that. Regarding user interface see screenshots by download links. |
01-21-2019, 09:47 AM | #16 | |
Rep 2
Yes you're right with me being an android user, sadly never been much of an iOS fan Thank you, your in depth help is much appreciated! Hopefully I wont end up setting my car on fire |
