10-07-2015, 11:42 AM | #1 |
34
Rep 167
jb4 install
Any pointers when installing jb4? i am going to a shop but wanted to check if there is any gotchas i should mention to them before they mess something up?
Thanks |
10-07-2015, 12:16 PM | #2 | |
BimmerPost Supporting Vendor
24199
Rep 190,807
http://www.burgertuning.com/instructions/f30_install.pdf
10-07-2015, 12:21 PM | #3 |
22
Rep 89
I installed it myself, took about 30 minutes... but that's because I never knew where anything was under the hood. After installing, you can literally do it in 10 minutes or less. You just unplug and plug in a few wires and splice in the 2 CAN wires, tuck them all away and that's it.
On the 2015, the color of the wires on mine were different on the car side, but I plugged them in exactly where they should go and they are all correct. I followed the install instructions available directly on the Burger website. |
10-07-2015, 12:23 PM | #4 | |
34
Rep 167
10-08-2015, 09:34 PM | #7 |
353
Rep 939
If your using the OBDii then you can change maps on the steering wheel. Check out www.n54tech.com
10-10-2015, 08:33 AM | #8 | |
151
Rep 179
11-28-2015, 04:31 PM | #9 |
432
Rep 938
I have a 13 with the pneumatic wg. I am going to get the blue tooth module, if i do that I don't need to hook up the OBDII connection wires then right?
Also what about the canbus non OBDII? Do I need to do that if i'm not hooking up with the OBDII port?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
11-28-2015, 08:43 PM | #10 | |
353
Rep 939
You either have to go OBDii route(recommended) or splice into the canbus. I believe all updated firmware will be for OBDii moving forward. Plus why would you want to splice wires? Blue tooth mode just allows you to change maps and log without hooking up a laptop, does nothing jb4 canbus control. |
11-30-2015, 05:37 PM | #11 | ||
24
Rep 167
11-30-2015, 09:58 PM | #13 | |
24
Rep 167
Ive read somewhere to keep away from battery rail as it may cause serious damage. I dont know where this rail is. |
12-01-2015, 08:16 AM | #15 |
36
Rep 374
Yup, thats exactly how I have mine
2024 X5 x40i
12-02-2015, 02:32 PM | #17 |
4918
Rep 115,980
12-02-2015, 05:04 PM | #18 |
24
Rep 167
Currently on map1. Haven't had a chance to fully test out but so far I do feel a bump in power. Im waiting for cp & dp so i can get on map2. Hopefully tonight i get a chance to test out and get some good pulls.
12-03-2015, 09:52 AM | #19 | |
4918
Rep 115,980
Mike |
