10-05-2015, 05:38 PM | #1 |
BimmerPost Supporting Vendor
9581
Rep 10,875
IND | Ground Control F8x M3/M4 Touring Camber Plates
Many of us are already familiar with the Ground Control brand, whose start in automotive specialty suspension components dates back to the 1980s. Their latest creation provides F80 M3 and F82/F83 M4 drivers with over 30mm of total camber adjustment and the ability to make 8mm of corrective caster changes. Each of their camber plate kits are assembled to order by hand from an assortment of precisely machined aluminum plates and fresh hardware. Features include waterproof axial load bearings, aerospace grade spherical bearings, and zinc plated or anodized components for stylish corrosion resistance. The Ground Control F8x M3/M4 camber plates are conveniently engraved, indicating plate location and torque specs for installation. As they are built to order, plates can also be configured to accept OEM or aftermarket springs and coilover suspensions. Ground Control F8x M3/M4 Touring Camber Plates $599 Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com The Ground Control F8x M3/M4 Touring Camber Plates may be viewed here in our online store: https://ind-distribution.com/product?sku=CCPF80] Our client's vehicle shown below is lowered on Swift springs, and OEM camber settings for daily driving.
01-19-2017, 09:26 PM | #2 | |
119
Rep 423
01-20-2017, 10:12 AM | #3 |
9581
Rep 10,875
Yes they should, will just need to know the Dinan spring inner diameter. I imagine they're the same as stock if originally intended to be used with OE top mounts.
02-14-2017, 01:25 PM | #5 |
9581
Rep 10,875
02-28-2017, 12:54 PM | #7 |
9581
Rep 10,875
