09-29-2015, 05:21 AM | #1 |
41
Rep 162
Y Cable with lightning connection
My iphone 6 won't work with the standard USB as I assume it's because I have the business media not pro and therefore don't have the combox? Not sure if this is true or not but I do know it doesn't work!
Wondered if the £10 Y cables from ebay that have the lighning connectors actually work, or if I need to fork out for an offical BMW Y Cable? Assuming they do them? |
09-29-2015, 07:08 AM | #2 |
18
Rep 60
I only have Business Media, and my iPhone 6 works fine without cables. You maybe lacking Extended Bluetooth which, if I understand correctly can be coded.
That's where my expertise ends I am afraid, someone else may pop in and deny/confirm. Jerry |
09-29-2015, 07:55 AM | #3 |
602
Rep 2,246
If I can find my OEM Y cable you can have that for free, as I have no requirement for it.
It has the 30 pin Apple connector and I used to run it with a 30 Pin/lightening adapter and it worked like a treat in my F10. You'll need a 30 Pin/Lightening adapter but I will check tonight when I get home. PM me if interested. |
