Speedometer not accurate/malfunction
09-26-2015, 02:22 AM | #1 |
Rep 31
Hey guys, hoping you could provide a resolution and some feedback. I am experiencing an issue with just my speedometer gauge. I filled up 91 octane today and hit the freeway, after driving 10 minutes I noticed my meter stated I was going 80 mph but didn't seem like 80, more like 65-70. Clearly my speedometer wasn't accurate. I decided to exit and see if my idle was normal. Sure enough every time I came to a stop my meter read 0 mph instead of idling at about 0.5 or 1. Speedometer is definitively not working accurately. Any thoughts what it might be? I have an 2012 335i coupe manual. About 50k miles. Any feedback or thoughts is greatly appreciated.
Thank you |
09-26-2015, 07:24 AM | #3 | |
648
Rep 2,011
335i e92 TPC 19Ts
09-26-2015, 09:24 AM | #4 |
75
Rep 731
Drives: 2008 335i 6MT
I have read this before as well.. I know the speedo is off, but why? Is there any real reason behind it?
2008 335i Coupe / Alpine White / 6MT / Fully Built Motiv Closed-Deck Motor / Motiv ST Kit / XR 105/69S / Motiv Twin Disc / VRSF 7.5 FMIC / ActiveAutowerke Exhaust / EOS Intake Manifold w/ 1050cc injectors / TiaL BOV / External VTA PCV / Quaife LSD / DSS Axles / KW V3Coilovers
09-26-2015, 09:34 AM | #5 |
7478
Rep 10,120
09-26-2015, 09:58 AM | #6 |
2032
Rep 8,339
It's off typically by 2 mph or so at 80 mph. Varies by tire diameter and wear. Use an aftermarket GPS to get true speed. My speedo is 1.5 mph fast at 84 mph.
09-26-2015, 10:03 AM | #7 | |
44
Rep 385
09-26-2015, 11:02 AM | #8 |
Curmudgeon and Pedant
690
Rep 3,489
All you have to do is Search, there have been many threads on this. Reason in a nutshell: EU and USA/CA laws require it. Look on Car & Driver's website for a good explanation.
09-26-2015, 11:14 AM | #9 | |
124
Rep 5,627
When you are stopped, your speedometer should naturally read 0 mph and your tach should read around 600 or 700 rpm. If, in fact, your tachometer reads 0 when stopped, either your motor has stalled or the tach is inoperative and should be repaired. Tom Last edited by Tom K.; 09-26-2015 at 11:20 AM.. |
09-26-2015, 08:33 PM | #10 | |
681
Rep 3,696
09-26-2015, 09:42 PM | #11 |
Is it the shoes!?
3884
Rep 5,112
It allows BMW to fit various wheel sizes with minimal changes. It's illegal for a speedometer to read even 1mph slower than you're really going, but perfectly fine if your speedometer reads 1mph faster than reality.
09-26-2015, 11:38 PM | #12 |
42
Rep 213
Lower speed vs indicated is a standard on European cars. The speedo cannot ever be over the actual speed. The USA deviation is 2-3 mph depending on your speed. The faster your speed, the higher the deviation. It's been liberally discussed in other forums.
2015 M4 Tanzanite Blue / Exec pkg / Driver Assist Pkg / LED Light Pkg /Blk 19" Wheels
09-29-2015, 01:42 PM | #13 | |
46
Rep 221
Glad to see I'm not the only one who thought the OP's concern that "I came to a stop my meter read 0 mph instead of idling at about 0.5 or 1. Speedometer is definitively not working accurately." was a bit odd.
2011 328i Coupe | Alpine White | Oyster/Black Dakota Leather | M Sport Package | Premium Package | iDrive | Harman Kardon Surround | Steptronic
12-12-2015, 07:51 AM | #15 |
107
Rep 161
Speedometer vs. Tachometer
I think we were the only ones who read the OP's actual post and not JUST the title. Willing to bet English is OP's second language. Hope they figured out the difference between "Speed"ometer and "Tacho"meter pretty quickly, it is kinda important.
v12 Flash, Turbonator, The Tornado, FD47 power booster, Turbo sound whistler, Nitrogen filled tires, The Ghost Pro, Joe Gibbs BR30, AFE DAS, Nut blast
12-12-2015, 08:44 AM | #16 |
353
Rep 1,245
My other car is a very nice '14 Honda Civic coupe (pretty darn sporty, actually).
I keep having to remind myself that the indicated speed in the Honda is REAL, unlike the BMW. It helps me keep my speed where it needs to be if I'm driving through an area known for speed traps. |
12-13-2015, 12:23 PM | #17 |
1903
Rep 6,968
You can get an app for your phone and measure actual mph. You can also code in mph in your screen where you can flip data such as mpg avg and actual etc.
You could also get bigger rims/ tires which would correct the situation almost entirely. |
12-13-2015, 12:35 PM | #18 | |
228
Rep 1,044
In my 2011 328i with 225x45-17 Contis this was verified against GPS reading. At 80mph (driving thru NV) the dial guage would read 84 mph, while the digital and the GPS both said 80 mph. A year ago I coded the digital speedometer display to be ON, turned OFF the digital 'correction', and the digital display MATCHES my GPS precisely. The BMW is this way because of EU regulations they must adhere to, which mandate that they never display a lower speed than actual, and I understand that the fines for them are massive.
From a Ferrari chat on web: "Well, at least my speedometer gauge said 165. The other day while testing out my 360, I noticed a huge discrepancy between speedometer and GPS. My GPS stated 136mph, but the speedometer specified 165mph. " and a response to that post, "Ferrari (and Lambo even more) speedometers have always been notoriously optimistic." Last edited by Wilt; 12-13-2015 at 12:47 PM.. |
12-13-2015, 12:41 PM | #19 |
1855
Rep 2,554
Well wouldn't that make 335 owners feel the same since it also gives them a false reading?
