Help - Start up and hazard button flashing
09-23-2015, 09:58 PM | #1 |
USMC
Rep 65
Looking for some guidance. Wife went to start the 2011 328xi after work and the lights just went crazy and would start. I showed up to give it a jump and all the accessories come on but when I hit the start button it kills everything. Take the key out pulled the cables off and the start circle, hazard light button and a clicking sound from the glove box started. Nonstop very quickly and no power at all.
Reading 7V at the jumper point in the engine bay. Where should I go next? Battery, starter... JBE? Thanks Eric V
“There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion.”
01 330ci/ 04 330ci/06 330i/07 328ci - gone 11 328xi - still stock |
09-23-2015, 10:16 PM | #2 |
Rep 18
Are you saying that it cannot be started while you jumped start-it ?
Unless there is a current drain somewhere, clearly, the no 1 suspect is the battery. It is almost impossible to start an engine with only 7v. Keep in mind that if you replace the battery, it should be registered in the onboard computer. |
09-23-2015, 10:18 PM | #3 |
53
Rep 199
your jumper cables are either weak or you did not give it enough time to partially charge completely drained battery. Regardless, the battery is a toast reading 7V. You need to get a new one first.
09-23-2015, 10:42 PM | #4 |
USMC
Rep 65
It was on there for a good while. I went through the fuse box checking all the start/stop related fuses. Damn hard to reach, at least they provided a crappy puller in there.
09-24-2015, 11:31 AM | #7 | |
681
Rep 3,696
You can get a new replacement battery from Advanced Auto Parts, all you need to know is if the OEM battery is a WHITE (this is a non-AGM) or BLACK (this is an AGM) color shell, also what is the Reserve Capacity (RC) number... that needs to match your new battery as close as you can get it. |
09-24-2015, 11:40 AM | #8 | |
228
Rep 1,045
09-24-2015, 11:57 AM | #9 | |
681
Rep 3,696
09-25-2015, 08:16 AM | #10 | |
USMC
Rep 65
Taking it to get registered Saturday am. Dammit just read the site autozone battery is AGM and I pulled out a white one. I've read people go from AGM to non-AGM and just code/register is the process still the same this way? Last edited by evill1; 09-25-2015 at 08:21 AM.. |
09-25-2015, 11:16 AM | #11 | |
681
Rep 3,696
Can you send me a linky to the battery you got from AZ and also what was your stock battery specs? |
