09-23-2015, 09:40 PM | #1 |
459
Rep 843
SOLD
4 - 225/45R18 Pirelli Winter Sottozero Serie II 240 4 - 18X8 ET32 ELBRUS I08 BMW center caps, and TPMS (will require new 433mhz sensors for newer models). Used on my previous car.. 2013 335i x-drive. Used two seasons, and tires only have around 3000mi on them. The car was turned in with only 13,000 miles total! Best tires I've used in winter and last year was the worst! Have an M3 now so these won't work. Rims have no curb rash or other damage. Pickup only, in Hartford, CT area.
Future Order: 2022 M4 Comp X, Portimao/KO
Previous: 2018 M3 ZCP, YMB/Silverstone 2015 M3, SO/Black Last edited by Rick955; 10-26-2015 at 12:54 PM.. |
09-25-2015, 10:30 AM | #2 |
212
Rep 774
09-28-2015, 08:51 PM | #3 |
459
Rep 843
Correct to both questions. Photo shows winter tire and wheel next to stock. All 4 are the same. One mistake...I meant three, not two seasons. 2012, 13, and 14.
Previous: 2018 M3 ZCP, YMB/Silverstone 2015 M3, SO/Black Last edited by Rick955; 09-28-2015 at 08:57 PM.. |
10-02-2015, 12:09 PM | #5 |
459
Rep 843
That's just too low. Sorry.
Previous: 2018 M3 ZCP, YMB/Silverstone 2015 M3, SO/Black |
10-05-2015, 05:38 PM | #9 |
459
Rep 843
I had no problem with mine. Should be fine 2012-2105 3 or 4 series, including Msport. I should have clarified in my original post that mine was an M Sport too, hence the Estoril blue.
10-08-2015, 08:43 AM | #11 |
459
Rep 843
Hope this helps. Brand new depth is 11/32". It's hard to measure with a tape measure which is all I have. Took some close-ups for you... note the original letters TW on the first photo, and in the second the original color stripes... blue tan are still there!
Previous: 2018 M3 ZCP, YMB/Silverstone 2015 M3, SO/Black Last edited by Rick955; 10-08-2015 at 08:52 AM.. |
10-08-2015, 07:32 PM | #12 |
1032
Rep 742
Drives: 22 M4c vert
Pm'd
10-09-2015, 05:31 PM | #14 |
459
Rep 843
I did not know, but I did find this... it appears that they will not work.
"The new F30 chassis uses a 433MHz sensor with OE#36106798872 which will not work with any of the previous versions." http://f30.bimmerpost.com/forums/sho...d.php?t=726432
10-23-2015, 01:25 PM | #15 |
459
Rep 843
Available again. Was going to use them on the M3 (they DO fit), but got a deal on a new setup.
10-24-2015, 08:39 AM | #17 |
459
Rep 843
Can't see why not... should fit any 3/4 series. Even fit my M, but the tires are just a bit small for the M. You will need new TPMS as BMW went to 433mhz on newer models.
