Dealer reset CBS oil/brakes service info, values are now invalid
09-23-2015, 01:51 PM | #1 |
46
Rep 221
I recently took my car in for a proactive (unprompted by the CBS computer) oil change at 7,500 miles because I prefer not to let it go 15,000 or more miles without service. The SA read the key and advised that an oil change wasn't due, and I explained that I like to have it changed at about half the CBS interval. I also mentioned that the computer indicated a rear brake service in about 3,000 miles and he said they'd check the pads and rotors and let me know what they looked like.
When I got the car back, I was informed that the rear pads/rotors were in good shape and would probably last longer than the 3,000 miles suggested by the computer. A day after this service, I pulled up the Required Service screen in iDrive and discovered that they had reset the counters for the engine oil and the front and rear brakes. The rear brakes monitor, which had indicated 3,000 miles a day ago, now shows 42,000 miles, and the front brakes monitor shows 70,000 miles, so it seems I have no way of knowing when these services should actually be performed. I called the dealer and the SA stated that it didn't matter because the computer would still alert me at the proper interval. Is this true? Is there any way to readjust the miles/dates in the computer to reflect something closer to reality (i.e., what it showed before the reset)?
2011 328i Coupe | Alpine White | Oyster/Black Dakota Leather | M Sport Package | Premium Package | iDrive | Harman Kardon Surround | Steptronic
09-23-2015, 02:52 PM | #2 | |
N52B25
15
Rep 196
Your dealer's reset of the CBS indicator for brake life is also normal given your complaint and it's exactly what mine did also (in my case CBS thought rear brakes were due for replacement and in reality they were not even 50% worn with 8-9mm pad remaining). CBS for brakes is notoriously unreliable for these cars especially before the first sensor has been triggered (i.e., before pads are 50% worn). I would not stress too much about this, the CBS indicator will become a little more accurate after the first sensor is tripped around 50% wear, and as an added safeguard you will get a continuous brake warning light when the second sensor is tripped around the time the brakes are completely worn. I also keep track of pad wear by physically measuring pad life a couple of times a year since I am taking the wheels off anyway to switch over to summers/winters. This is definitely the best way to ascertain actual wear but may not be practical for you depending on how comfortable you are jacking up the car and taking wheels off (or depending on wheel style you can sometimes peek between the spokes and get a rough measurement). |
09-23-2015, 03:44 PM | #3 | |
228
Rep 1,045
When the CBS then told me in August 2014 that oil change was due, they changed oil and filter and microfilter and reset the oil service reminder. If the tech had read and complied with the the service order instructions (in August 2015), they would NOT have reset the SI, but the tech didn't follow instructions so they reset it after all! So I am now 13000 miles from my next microfilter, theoretically, which is about 1.4 years away at the rate I accumulate miles. The CBS being so far off is of little consequence, it is a 'guess' based upon your driving habits. Pay attention to mechanic status reports on pad thickness based upon visual inspection...below 5mm you are getting close to needing pads. And the sensor will absolutely tell you 'get pads now' with a warning light. Last edited by Wilt; 09-23-2015 at 03:50 PM.. |
09-24-2015, 06:48 AM | #4 | |
46
Rep 221
Are there two different warning lights for brake service - one for "service approaching" and another for "service due NOW"?
09-24-2015, 07:26 AM | #5 |
313
Rep 661
Why wouldn't you want your CBS data corrected to reflect proper service intervals...
Winter: 13 PGM 3.5 E70|MHD
Summer: 15 6MT BSM F80|MHD|KW|SM-10 Gone: 09 AWD 6MT AW E90|FBO|MHD|XHP|KW|ARC-8 IG: 475_f80 |
09-24-2015, 09:41 AM | #6 | |
N52B25
15
Rep 196
Yep, CBS for brakes is a two sensor system, first is triggered around the time brakes are 50% worn (which helps CBS better gauge wear from that point forward, but no warning light is illuminated) and a second which when tripped will light up the a brake warning light which will stay on until you replace the sensor & reset CBS. There are a few other threads on here that explain CBS for brakes in really good detail. |
09-24-2015, 10:05 AM | #7 | |
266
Rep 952
My projected service interval for the rear brakes has been 3100 miles for the past year. The pads have more than this left on them, so somehow when the dealer changed the pads, the old sensor was re-used, or something.
bone stock
09-24-2015, 10:06 AM | #8 | |||
46
Rep 221
Thanks for your help!
09-24-2015, 10:18 AM | #9 |
17309
Rep 18,733
I just don't understand the difficulty of people understanding how the brake pads monitor works. The front left and right rear brake have sensors. The sensors are consumables. The sensors are dual-stage that is needed to estimate the rate at which the pads are consumed. This determines the estimate of remaining pad life in mileage. But in the end, the system tells the driver when the pads need replacement. All you need to do is wait until the notification shows up in the gauge cluster.
