whining noise under hood
09-23-2015, 10:16 AM | #1 |
43
Rep 269
2011 335i x coupe (n55) after the car is running for a brief trip it starts to make a whining noise. it usually seems to occur after the rpms drop like when I am sitting at a red light, but it could be that it is drowned out while I am moving. It does not do it ALL the time when its just idling, but usually after even a short drive. can anyone give me an idea of what this is? video below
09-23-2015, 10:52 PM | #2 | |
139
Rep 1,271
2007 335i Jet Black e92 6AT - VRSF Full street exhaust DP, Chargepipe 7.5 FMIC, MHD, XHP, Koni orange/Eibachs, some other stuff
2007 335i Jet Black e90 6MT - Eibachs, magnaflow exhaust, carbon hood, short shift kit, some other random stuff - being sold somewhere sometime soon probably 2010 335i AW e90 6 AT Msport - The GF took this one over... JB4, PE exhaust, Koni yellows/Eibachs, pink badges, fuzzy steering wheel cover ? |
19jdog86.50 |
09-24-2015, 04:46 AM | #3 |
700
Rep 1,227
its difficult to tell without being there to try to determine what area the noise is coming from. I would start by checking the drive belt since that is the most likely culprit.
09-24-2015, 07:51 AM | #5 |
28
Rep 583
I'm having a very similar noise, seems to only happen when it's cooler outside. To me it sounds similar to the sound that people have reported on here that ended up being the crankshaft seal.
see this thread... http://www.e90post.com/forums/showthread.php?t=629612
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
09-24-2015, 03:49 PM | #7 | |
43
Rep 269
09-27-2015, 04:21 PM | #8 |
43
Rep 269
would I notice any oil or fluids leaking if it was the crank shaft seal? Also does anyone have an estimated cost of the job if thats what it is, want to prepare my wallet/anus before I take it in this week.
09-28-2015, 10:32 AM | #9 |
19
Rep 188
im almost sure its your idler pulley. mine broke in half last winter in my e46 m3 and was making a very similar noise
milkmaster24.50 |
09-28-2015, 11:42 AM | #10 | |
28
Rep 583
09-28-2015, 12:01 PM | #11 |
132
Rep 318
That sound is not coming from your crankshaft seal, it's more common to come from a pulley, and it's so easy to test if one of your pulleys is the culprit. With the engine running (idling) just put some water with the water hose on each of the pulleys, if the noise is gone, one or some of your pulleys need to be replaced.
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i '19 G01 X3 | Wife's '15 F30 335i M-Sport | Son's '10 Porsche Boxster |
09-28-2015, 09:29 PM | #14 |
28
Rep 583
Mine is so rare, happens maybe once a month for a few minutes then disappears
10-03-2015, 01:48 PM | #15 |
43
Rep 269
Well I was just told by the shop it is definitely coming from the transmission, trans guy isn't in today so it goes back monday. Any guesses? this sounds expensive, and its also progressed to be much louder and constant
10-13-2019, 02:57 PM | #17 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
Don't worry it's just the supercharger
Common sense is a flower that does not bloom in everyone's garden
10-13-2019, 03:56 PM | #18 |
3058
Rep 3,910
10-13-2019, 09:50 PM | #19 |
611
Rep 1,272
10-19-2019, 09:16 PM | #20 |
Rep 2
So the noise comes from the valvetronic system. I bought a Foxwell NT510 and it showed a valvetronic error. The NT510 has a valvetronic "learning" function. Ran the test and the noise immediately went away. Its possible it might rear its ugly head again but at least I know what it is. The NT510 has already paid for itself.
