What size wheel spacers should i get?
09-21-2015, 01:10 PM | #1 |
15
Rep 46
Drives: 09 E90 330D
I have an 09 LCI E90 with 18" BMW style 189 alloys and was wondering what size springs and spacers would fit without rubbing, or is this just not possible to do both?
From what i can tell online, the wheels are staggered, 18" X 8.5 rears & 18"x 8 Fronts. I initially want to get spacers (as they are cheaper!) and then springs. Could anyone advise me on what sizes is should be looking at? Its currently sitting on "sport" suspension (the factory extra, but not m sport) with no spacers.
My Build Thread - Crimson Red E90 330d
09-21-2015, 03:31 PM | #2 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
uh, spacers and springs don't do the same thing, not even close.
It's pretty widely known with stock bmw 18 staggered fitment, you do 12mm front with 15mm rear. Or 15mm all around. eibach pro-kit, h&r sport springs work just fine... also, you need to post here: http://www.e90post.com/forums/forumdisplay.php?f=12 |
09-21-2015, 03:59 PM | #3 |
71
Rep 477
Depending on how much you lower the car, 15mm on the front will most likely rub. I would do 12mm front with 15mm rear OR 10mm front with 12mm rear.
If you do springs, make sure to the the struts as well. If you plan to re-use the OEM struts, the ride tends to be a little floaty and they will leak in a short amount of time. I've done this before trying to save a few bucks. |
09-22-2015, 02:51 AM | #5 |
77
Rep 980
Drives: '08 BSM 335i e92
FWIW I am currently running 12.5mm front and 15mm rear. I have a bit more room in the rear and I could probably get away with 18mm in the rear if I wanted to. I'm slammed on KW V1 coilovers too.
'08 BSM E92 335i 6MT/MHD stg 2+/VRSF 7" FMIC/VRSF CP/HKS BOV/VRSF catless DPs/BMS DCI/muffler delete/BC Extreme lows/OEM style 167s/BMS high side OCC/Mishimoto low side OCC/etc
09-22-2015, 04:43 AM | #6 |
15
Rep 46
Drives: 09 E90 330D
Thanks for all the replies chaps!
Is this with style 189 alloys?
09-22-2015, 02:32 PM | #7 |
15
Rep 46
Drives: 09 E90 330D
SO - if i were to space 10mm on front and 15mm back, wha size springs should i be buying to pair with that and get no rub? - if any one knows.
Thanks again
09-23-2015, 02:03 AM | #8 |
77
Rep 980
Yes, I'm running factory style 189 wheels. Factory tire sizes, 225/40R18 fronts and 255/35R18 rears.
09-23-2015, 06:14 AM | #9 |
71
Rep 628
Drives: ...when not replacing gaskets
I have 20mm on the rear on stock suspension. Some rubbing when I hit a dip in the road but that's with three passengers.
Tags |
e90, lowering, spacers, spacing, springs |
