Valve cover Gasket Replacement- Use RTV?
09-21-2015, 11:29 AM | #1 |
149
Rep 460
I'm going to be changing out the valve cover gasket on my 2007 335i this weekend. Searching the forum I'm reading mixed advice on whether to use any RTV sealant when you do it. Also, if yes exactly where?
09-21-2015, 12:42 PM | #2 |
267
Rep 1,203
Have done, upwards of 100+ valve cover gaskets. I've never used RTV while doing a valve cover job on any N51/2/4/5..They don't come from the factory with any on it. To each their own
Antetokounmpo1551.50 |
12-27-2018, 09:54 PM | #6 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
Good info. Thanks!
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
12-27-2018, 11:26 PM | #8 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
hmmm I couldn't check the back of mine, I tried to get it seated really well in the cover when I did it last weekend. fingers cross i guess haha
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
12-28-2018, 12:29 PM | #9 |
449
Rep 1,327
You could have used a small mirror they sell at Autozone for $1.99. I just used one last night to install my new valve cover.
12-28-2018, 03:54 PM | #10 |
ziddak
17
Rep 38
I'll share a trick I learned years ago at GM Tech center.
Be sure valve cover and head are CLEAN! Use SMALL DABS of 3M super weatherstip adhesive on the surface of the valve cover and attach the gasket. Let it dry! The small dabs of the adhesive will not affect the gasket but simply hold it in place when you re-install it onto the head. I've done this on all kinds of gaskets where slipping could be an issue. Works like a charm. And stay away from RTV! If that stuff gets into your engine it's bad news! |
12-29-2018, 09:45 AM | #12 |
398
Rep 1,579
I use the smallest amount possible of RTV. It is a super thin coat on the gasket that does not squirt out when compressed. My thinking is the OE without RTV can leak after a few years. My 06 N52 was done in 09 with RTV and still not leaking.
12-30-2018, 12:33 AM | #13 |
449
Rep 1,327
I did it with RTV about 3 years ago on my previous 335i. No leaks. I just did it on my E90 without any RTV last night. Let's see if it holds up.
12-30-2018, 08:01 AM | #14 | |
17309
Rep 18,733
Sometimes a small zip tie through a few bolt holes helps keep the gasket in place. Once set, cut the tie and pull it out.
12-30-2018, 08:19 AM | #15 | |
149
Rep 460
12-30-2018, 11:10 AM | #16 |
2440
Rep 4,330
05-27-2020, 04:48 PM | #17 |
52
Rep 116
Valve cover gasket replacement info
Hi everyone! I completed this project a while back and lets just say I hope this leak does not come back haha. I will post my video that has all the tools and sources you'll need when completing the valve cover gasket replacement while adding DIY videos in the description.
Email: bmwyt0@gmail.com Video Link to my channel |
05-27-2020, 05:53 PM | #18 | |
1903
Rep 6,968
You won't find hardly any negative posts from people who used Ultra Black, let it cure for 24 hours prior to start up in combination with an a OEM gasket. The Key is to put a bead of Ultra Black on the VC, place the OEM gasket into the groves of the VC where you just put a bead of Ultra Black prior. Then put a second bead of Ultra Black on the gasket. Maybe let it set up for 10 min prior to carefully placing the VC on the head. This process might be a 2-person job considering all the wires that might be sort of in the way. I bungee cord mine back & they are still an obstacle you have to negotiate, in order to put the VC on the head correctly. If you do this procedure exactly as I stated above & wait 24 hours for the sealant to fully cure before start up, then in all likelihood, you have bought yourself 10-20,000 extra miles before you will eventually have to replace it again. |
05-28-2020, 03:35 PM | #19 | |
17309
Rep 18,733
05-28-2020, 05:01 PM | #21 |
1006
Rep 2,243
Drives: 2007 328i / 2014 M235i
Either way you will be fine if you use a quality gasket.
I didn't want to but I had to do it could hold in place. I put a very light coat and when I think about it, silicone is a good lubricant and will prevent it from drying out. It's not done in the factory because it adds a second step which is very costly and the risk of adding to much to be high. |
05-28-2020, 05:37 PM | #22 |
Robot
1685
Rep 2,190
Which implies, according to every comment that the factory oil pan gasket, valve cover gasket, and oil filter housing gasket WILL leak, that the factory gaskets aren't quality gaskets.
I'm aware that the BMW OEM part for the oil filter housing gasket is now made in Japan. This sounds promising. I'm not aware of such a change for the oil pan and valve cover gaskets. When I do my oil pan gasket, it's getting a super thin coat of permatex ultra black. |
