335i screeming high pitch when revving fast
09-19-2015, 11:22 PM | #1 |
40
Rep 1,283
My 335 N54 suddenly start having a high pitch screaming when rev it fast as the video attached. If rev it up slowly or rev at neutral, it won't scream! Any idea?
https://youtu.be/RWNfu1hyG6E
08 Montego Blue E92 335i 6MT sp Navi with beige interior
aero front, Mtech side, M rear lip spoiler, hid fog, 19" Work Varianza T1S, KW V2, Mtech steering wheel, shift knob, e-brake handle & alumnium pedal |
09-20-2015, 02:24 AM | #3 |
14
Rep 31
Drives: 2007 E92 335i
Sounds awful and my guess is a belt, tensioner or pully issue. please have it looked at promptly and good luck.
09-20-2015, 02:50 AM | #4 |
296
Rep 2,015
You better make sure your belt is not partially torn.....Google 335i shredded belt.
You won't like the end results....like engine replacement. But if it is the belt..... Look up my DIY on N54 serpentine belt, Tensioner, and upper and lower pulley replacement. DN |
09-20-2015, 09:31 AM | #5 |
39
Rep 592
How many miles on car? Lots of posts over the years questioning WHEN the belt should be replaced. Don't recall any video or sound description quite like that. Good luck and let us know the outcome.
Evolution Racewerks FMIC and Charge Pipe with TIAL-Q.
Wedge Tuned 93 Oct, K&N Panel, Conti DWS 245/275. |
09-20-2015, 10:25 AM | #6 |
300
Rep 3,969
Have that looked at pronto!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
09-20-2015, 04:57 PM | #7 | |
40
Rep 1,283
09-20-2015, 04:58 PM | #8 |
40
Rep 1,283
less than 58000 miles
09-20-2015, 05:58 PM | #9 |
228
Rep 1,045
I have had tensioners and pulleys wear out on an E46...it simply squeaked/chirped.
Lack of sufficient tension might result in slippage of the belt as the engine suddenly revs to higher rpm, for that howling to result. |
09-20-2015, 06:46 PM | #10 |
40
Rep 1,283
hm... but my car other than the scary scream, drive nothing wrong and also no problem to start
09-20-2015, 06:56 PM | #11 |
228
Rep 1,045
Yeah, and other than the squeak annoying me mostly when a window was open, there was nothing wrong with my E46 either, when it needed a tensioner or pulley. I brought the car in for other routine service (oil change), and asked the SA to have the squeak investigated. They reported by phone 'tensioner' or 'pulley' and I authorized the work and then picked up the car. It was still normal (like when I dropped it off), but not squeaky.
Have them check it out, if it is simply the need to tighten things, maybe it is a good indication to change the belt for a new one (which is not drying out and having a polished surface from the slippage on rotating surfaces Last edited by Wilt; 09-20-2015 at 07:01 PM.. |
09-26-2015, 05:58 PM | #12 |
40
Rep 1,283
My mechanic found out it was because the host that connected to intercooler was cracked! He need to order a replacement, the parts won't be expensive but require some labour work
09-26-2015, 08:25 PM | #13 |
681
Rep 3,696
if your already gonna pay for intercooler labor... you might as well swap out the stock intercooler for an aftermarket intercooler. plus while the intercooler is out... easy to drain and refill your coolant.
09-26-2015, 08:42 PM | #14 | |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
But you haven't noticed a loss in boost..?
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
09-26-2015, 10:18 PM | #15 |
40
Rep 1,283
already with 7" upgraded intercooler
09-26-2015, 10:20 PM | #16 |
40
Rep 1,283
After I heard the noise, I didn't drive it hard at all to feel losing boost. But for regular driving, no power loss being feel
