Can someone help me with my lci2 install?
09-19-2015, 02:15 PM | #1 |
657
Rep 1,749
I'm adding an amp via technic harness and having trouble with which inputs go into the lci2 2?
I'm tapping the blue wire for 12v turn on and then which slot does that blue wire go into on the lci2? 12v or remote on? Which other wires need to go into the lci2 besides technic piggy which is pretty wired and plugs in. Also the technic piggy which is the output from the amp, I assume you just run speaker wire from the amp to that piggy and hook up the wires by splicing or connecting them? Any other tips? |
09-20-2015, 12:31 PM | #2 |
657
Rep 1,749
Ok I've figured out the wiring but one remaining question is what power kit do people use to power the lci2? Lci recommend a 1A fuse but I can't find any amp wiring power kits using such a small fuse. So what wiring kit are people using to power and ground their lci2?
