service light won't go away
09-18-2015, 09:09 PM | #1 |
Rep 146
2010 335i lci.
whenever the car is started up a service light comes on. i used acutron scanner to "erase it" but it doesn't work. anyone have this problem and/or know how to fix it? thanks |
09-18-2015, 09:32 PM | #2 |
3788
Rep 5,776
Did you scroll through the onboard display and look for messages? And if it is service engine soon you need to check for codes.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
09-19-2015, 09:15 AM | #3 |
432
Rep 1,602
How are we going to know what the problem is without giving the code that goes with it? Scan it and post the code? There are like 1000 of them...kind of hard to narrow down.
09-19-2015, 10:06 AM | #5 |
39
Rep 592
I assume you don't have IDrive so you will need to just the controls on the turn signal controllers to navigate to the service items. This is a maintenance (oil, brakes, etc) reminder not a Check Engine Code.
Evolution Racewerks FMIC and Charge Pipe with TIAL-Q.
Wedge Tuned 93 Oct, K&N Panel, Conti DWS 245/275. |
09-19-2015, 10:11 AM | #6 |
352
Rep 2,050
Is it the service engine soon light ?
For that, erasing the codes won't fix the problem. Or just saying your car needs service ? That's another issue. Could be damaged wires going to the oil sensor
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
09-19-2015, 10:12 AM | #7 |
533
Rep 2,872
The car is trying to tell you there's a problem, clearing the code doesn't fix the problem.
Next time it comes on, read the code, and post it here after you google it to find out what's going on. What does the light say exactly? Service engine soon? |
09-19-2015, 10:49 AM | #8 |
228
Rep 1,045
Your car could be telling you that some routine maintenance has become due.
Your car could be telling you something has gone wrong and needs attention. You need to better understand WHICH of those two things is causing the light, but simply clearing a light does not make the NEED go away, which is why the light comes back. The urgency of the attention really depends upon any reported ERROR CODE that an OBDII scanner can tell you...some are 'stop driving and shut off the engine now!' urgency, others are less urgent! |
09-19-2015, 10:51 PM | #9 |
60
Rep 675
09-20-2015, 12:45 PM | #10 |
1911
Rep 13,103
If its a brake sensor it won't go away till you fix it.
If its a brake sensor (that is now warn through)it won't go away till you fix it.
It won't let you reset a brake job. |
Tags |
335i, bmw, lci, scan |
