09-18-2015, 09:06 PM | #1 |
1836
Rep 4,203
Help advise on brake rotors M235i
So i am in the market for some bling and rotors is it's name. Help me deside what is about the best for a daily driver and spirited week end runner. WIll be running low dust semi metalics
So which one? High carbon cross drilled High carbon slotted High carbon dimpled & slotted Cannot get drilled and slotted..... I do not know how to set up a poll |
09-20-2015, 10:26 PM | #2 |
NewFinishColumbia/detailer
604
Rep 2,096
If you plan on driving hard at all don't get anything but slotted. The drilled or drill/slotted will crack from the heat.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
09-21-2015, 09:44 AM | #3 |
41
Rep 197
09-22-2015, 01:25 PM | #5 |
377
Rep 596
Drilled = looks only
Vented & Slotted = true performance Why do F1 and LMP cars run vented only? Because drilled rotors crack under high temp gradients. |
09-22-2015, 09:27 PM | #6 |
153
Rep 446
09-29-2015, 08:47 PM | #7 |
125
Rep 356
As others have said, if it's for looks then cross drilled is fine. If you're looking for performance than you need regular blank rotors......yes, seriously, blank rotors.
09-30-2015, 02:51 PM | #8 | |
743
Rep 893
2019 SG M5C
2015 SO M3 6MT 2015 BSM M235xi |
09-30-2015, 06:59 PM | #9 |
1836
Rep 4,203
I am surprised that BMW would spec their top models with drilled rotors if they are not as durable, efficient and overall work better. Maybe peeps just buy M's for the looks
I do not plan on tracking my 235 but am ditching the pads due to all the black brake dust so figured I would ad some rotor bling at the same time |
09-30-2015, 07:02 PM | #10 | |
451
Rep 845
Slotted is sort of useful. If you are driving in the rain (or snow), the slots help move water away from the pad. It also (somewhat) helps with heat buildup, but not nearly as much as venting the discs. The effect on the structural integrity of the rotor is much smaller than cross-drilling. Still, if you are driving your car like an F1 or LMP1, then you just want (I think) blank, vented rotors.
