2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning F Chassis Tune Comparison N20/N26/N55/S55 - LAST UPDATE 02/12/2018 ** Active Added
      09-15-2015, 08:30 PM   #1
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
24095
Drives: 07-335/12-328/18-M4/21-M4CP
Talking F Chassis Tune Comparison N20/N26/N55/S55 - LAST UPDATE 09/19/2018 ** Active Added
This post is copied from Extreme Power House's Blog
Today, I would like to write about the different piggyback options available for the BMW new F chassis cars. This market is oversaturated with tunes priced from a couple hundred dollars up to a couple thousands. Not all piggybacks are equal, which ones are worth it and which ones are not? Read this post and decide for yourself.
DINANTRONICS Sport Performance Tuner
How:
Connects to TMAP sensor only
Pros:
  • Easy install
  • adjustable boost 0 to 4 psi
  • Very reasonable price
  • Same tune fits the N20, N26 and N55 F chassis
Cons:
  • No datalog feature
  • Does not have access to ignition timing
  • Does not carry the same warranty as other Dinan tunes
Price:
$299
Burger Tuning F Chassis N20/N26/N55 JB+
How:
JB+ connects to TMAP sensor only.
Pros:
  • Install time takes less than 5 minutes
  • Adjustable boost ( 0 to +4 psi)
  • Costs less than $200
  • Not engine specific. Fits on most N20, N26 and N55 cars
Cons:
Price:
$199
Active Autowerke Active 8 Tune
How:
A8 tune works by connecting to the Manifold air pressure sensor, boost pressure sensor, camshaft sensor and air mass sensor.
Pros:
•Since the A8 connects to the camshaft sensor, it controls boost by RPM. The ability to do so offers a smoother / more linear power delivery.
•9 different maps (Compatible with catted downpipe cars only and pump gas).
•A8 is offered standard with a waterproof enclosure.
Cons:
•Install process is the most time consuming for a stage 1 tune (although it has quick detach button to uninstall the module, but not the wires).
Price:
$699 for Non-M models / $999 for M models.
AFE Module Scorcher
How:
AFE scorcher connects to the MAP and TMAP sensors of the car. It alters the pressure sensor signal to increase turbo pressure.
Pros:
•AFE is easy to install with only 2 sensors. It offers a clean solution for more power.
Cons:
•AFE Scorcher offers no flexibility for the user. It is available with 1 map only and no option to adjust boost.
• It does not have the ability to control boost by RPM, the Scorcher adds a constant boost value across the RPM range.
Price:
$473 for Non M Models / $627 for M Models
Burger Tuning JB Stage 1:
How:
The BMS JB stage 1 connects to the MAP and TMAP sensors and works by altering the boost pressure signal (identical to AFE and Race chip ultimate).
Pros:
•Easy install, takes less than 10 minutes.
•BMS JB stage 1 gives its users the ability to increase boost if he / she is looking for a more aggressive map (will need an optional $35 BMS Data Cable).
•Weather proof box is optional and will cost an additional $59.
Cons:
•JB stage 1 does not have the ability to control boost by RPM. It adds 3.5 psi across the RPM range over stock boost (value can be changed using the USB cable).
Price:
$379 for M and Non-M models
Burger Tuning JB4 Stage 2:
How:
The JB4 stage 2 connects to the MAP sensor, TMAP sensor and Canbus. It is also offered with flex fuel wires for E85 users.
Pros:
•Pre-loaded with 7 maps each optimized based on the car’s modifications and fuel. The Jb4 is also offered with a custom map allowing the user to set his / her own boost targets.
•The Jb4 controls boost by RPM. It also controls boost by gear and can set a max boost limit for the first 3 gears in order to achieve better traction control.
•The JB4 stage 2 can read / delete codes and auto clear the CEL code in case car has catless downpipes installed.
•The JB4 is compatible with E85 fuel as long as the mix does not exceed the fuel pumps maximum capacity.
•The JB4 is capable of gauge hijack and can control the exhaust valves for a louder exhaust sound.
•Ability to get free firmware upgrades from the user’s laptop without the need to ship the module back every time an upgrade is available.
•Option to get the Jb4 with a weather proof case; it will cost the user an extra $59 for the aluminum enclosure (No additional cost for M cars).
Cons:
•In order to achieve all these pros mentioned above, user will need to purchase the optional USB data cable and / or OBD cable ($17 for the OBD cable and $35 for the USB cable).
•Install time takes around 45 minutes because of all the extra connections that the JB4 needs.
•If user does not purchase the OBD cable, JB4 will need POSI-Tap wires to connect to the Canbus.
Price: $529 for Non-M Models / $799 for M models (Aluminum enclosure and OBD cable is offered with the M series JB4 at no extra cost).
Race Chip Ultimate:
How:
RCU connects to the MAP, TMAP and MAF sensors and work by changing boost pressure signal and tricking the ECU into making more power.
Pros:
•Easy install
•Weather proof box (standard)
•9 different maps
Cons:
•Cannot control boost by RPM
Price:
$679 for M and non-M models
ESS E-tronic Tuner
How: The ESS tuner connects to 4 sensors. Intake Cam shaft, Map, TMAP and MAF.
Pros:
• Control boost by RPM for a smoother power delivery
• 3 different maps
• Standard weather proof enclosure
Cons:
• One of the hardest stage 1 tunes to install
Price: $995 for all models
Dinan Tune
How: Dinan connects directly to the ECU to cover as many sensors as possible. It adds a constant boost value to the car across the RPM range (3.0 psi for stage 1 and 4.0 psi for stage 2).
Pros:
• If BMW denies your warranty claim, Dinan will cover any damages caused or related to any of Dinan tunes or parts
• Weatherproof box
• CARB certified
• Tune monitors and adjust AFR / ignition timing for a smoother power delivery
• Increases water pump pressure for better cooling
Cons:
• You get 1 map with each tune only
• Install time takes from 1.5 to 2 hours
Price: $1499 for the stage 1
Summary Table:
Tune Comparison.doc
Active Autowerke OBD Flash Tune
How: Connect Simon Cable to OBD port and upload your new map (No ECU removal needed).
Pros:
  • Smooth stock like power delivery
  • unlimited number of maps (2 off the shelf maps, 4 free custom maps included with the tune, additional custom map $50 each)
  • No hardware installation needed
  • Locks flash counter until stock map has been re-uploaded
  • Ability to upload stock map at any time
Price: Starts at $800
Bootmod3 By PTF
How: Connect Enet cable to OBD port and upload your new map (No ECU removal needed).
Pros:
  • Mobile app (iOS and Android)
  • Datalogging over 200 diagnostic channels, up to 40 channels concurrently
  • atalog sharing and charting without a need to upload to 3rd party websites or apps using the mobile app or web browser
  • Cloud based storage for map data and datalogs
  • Reverting back to stock performance map and re-locking the DME to stock programming
  • Live Dash - realtime vehicle parameter monitoring via in-app guages
  • Read and clear trouble codes in all vehicle modules
  • Reset learned adaptations (octane, knock, Valvetronic, etc)
  • Custom tuning available
  • flash time (map switch) is 30 seconds
  • first flash to unlock is just 3.5 minutes long
  • no special hardware to ship, instant activation at time of checkout
  • boost by gear
  • transmission flashing
Cons:
  • 1 OTS map is included with the license. it costs extra to unlock all the OTS maps.
  • similar to all flash tunes, on the fly map adjustment not available
  • Raising and lowering boost requires tuning knowledge
Price: Starts at $595
https://x-ph.com/sale/
Phone number 702-494-9435
Poochie9103.00
      09-17-2015, 03:28 PM   #2
uberspeed
45
Drives: 328i
Thanks!
      09-18-2015, 12:16 PM   #3
mike@x-ph.com
24095
Originally Posted by uberspeed View Post
Thanks!
You are welcome
More tunes will be added soon
      09-18-2015, 01:01 PM   #4
uberspeed
45
Drives: 328i
I'd definitely like to see how these stack up to the ECU tunes starting to trickle out now but for plug and play solutions it's nice to see options in the marketplace!
      09-18-2015, 01:03 PM   #5
mike@x-ph.com
24095
Generally speaking piggy and ECU would give you the same power.
ECU flash offers smoother power delivery , Piggy offers more features, more flexibility, multiple maps and ability to make changes from your home for free.
And as you know at this time all ECU flashes will require you to send the ECU to the shop to get it tuned
      09-18-2015, 02:19 PM   #6
uberspeed
45
Drives: 328i
Yes sir indeed, long time APR user on VAG platform. When I go from F30 to F22 I'll definitely be revisiting this, staying informed in the meantime.
      10-01-2015, 02:26 PM   #7
mike@x-ph.com
24095
Dinan tune added to the first post and the summary table
      10-01-2015, 03:36 PM   #8
Dinan_Engineering
Dinan_Engineering's Avatar
3903
Drives: Any BMW
Not compatible with catless downpipes is not technically true. It will work with catless downpipes just fine. Just won't clear the associated CEL.
      10-01-2015, 03:41 PM   #9
mike@x-ph.com
24095
Thank you for clearing that up.
What is meant by non compatible is that Dinan does not have a map optimized for catless downpipes.
Every tune in this post works with catless downpipes, some of them do not have specific maps for DP thats why they are listed as non compatible.
      10-01-2015, 04:15 PM   #10
Dinan_Engineering
3903
Drives: Any BMW
Fair enough but non-compatible implies it does not function when downpipes are applied. More accurate statement would be "not optimized" for catless downpipes. Mincing words technically but still...
      10-01-2015, 04:16 PM   #11
mike@x-ph.com
24095
You have a point, i will go ahead and change it
      10-01-2015, 04:19 PM   #12
mike@x-ph.com
24095
Done
      10-03-2015, 10:46 PM   #13
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Btw, RaceChip Ultimate for the N20/N26 connects to MAP, MAF and TMAP (ability to do so offers a smoother / more linear power delivery.)
Has more than 3 maps too , 9 different maps (Compatible with catted downpipe cars only and pump gas).
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      10-04-2015, 03:30 PM   #14
mike@x-ph.com
24095
Fixed , thank you.
The old stage 1 JB used to connect to the MAF but they removed that sensor because it showed not to offer any additional benefit.
      10-29-2015, 04:47 PM   #15
Ramsen
Drives: BMW 228i M-Sport 6MT
Thanks for this. Will you add the GSR tune?
      08-16-2016, 05:02 PM   #16
mike@x-ph.com
24095
Jb+ added
      08-17-2016, 11:16 AM   #17
f22b58
67
Drives: BMW M240i
The JB4 I got for my N26 F22 came installed in a weather proof enclosure and the CANBUS cable was included. If I feel the need for data logging or a firmware update I have the choice of purchasing their Bluetooth module and compatible smart phone app. A definite pro of the JB4 is that it is several products in one.
      08-17-2016, 12:22 PM   #18
mike@x-ph.com
24095
JB4 is the most complete piggyback system available on the market
What do you think of the extra power increase?
      09-13-2016, 04:01 PM   #19
mike@x-ph.com
24095
Dinan sport performance added
CalCarNut1060.50
      09-20-2016, 11:15 AM   #20
hoppy6698
hoppy6698's Avatar
127
Drives: M235i, Estoril Blue on Black
Enzo or only doing DIY tunes?
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      09-20-2016, 11:30 AM   #21
mike@x-ph.com
24095
I will probably add flash tunes as well
      09-26-2016, 08:33 AM   #22
D Unit
93
Drives: 2013 x1 s28i
Subscribed. Great thread OP.
2addicts
