335i Sedan Rear Driver Side Window is stuck down!
09-14-2015, 01:46 PM | #1 |
22
Rep 257
Hey all, I guess my window regulator is toast on the rear driver side and to make matters worse... the window is 100% down. Any idea how to temporarily have the window stay all the way up while I figure out which route to go with repairing it. Anyone have an experiences with aftermarket regulators? Theyre 1/3 of the price. Help!
09-14-2015, 02:15 PM | #3 |
just another bmw douche bag
195
Rep 3,640
you can get regulator assemblies off eBay. Also, you probably don't need a new motor, and can re-use your old one. Don't dick around with the switch though, or the motor will suck in the cable and screw everything up.
I folded up some paper used it as a wedge to keep the window up. shove it between the glass and the inside of the frame. tape it in place if you have too. |
09-14-2015, 04:57 PM | #4 |
17
Rep 274
Can you hear the motor grinding the cables? It may not be a complete failure. My window sometimes gets stuck and all it takes is a 'reset' via the window switch. Hope you get it figured out.
09-14-2015, 07:52 PM | #5 |
32
Rep 273
Had the same exact issue 3 weeks ago, motor went down but didn't come back up. You can hear the motor moving when you push the button. I ended up picking this regulator up from ebay, took about 2 hours to install but if I had to do it again I could probably do it in 30 minutes.
http://www.ebay.com/itm/131027986443...%3AMEBIDX%3AIT Also you'll probably have to reset the window after installing it, I did it through INPA but I think there's a way to do it by holding the window button in the up and down positions for a few seconds each. |
09-15-2015, 06:28 AM | #6 |
51
Rep 308
Drives: 2007 328i
Happened to me... luckily window was still up... I used some black molding tape to hold windows up around the edges. Could hardly see it. I did the $20 cable kit. Was a pita getting it set up but the whole job is cake really.
09-15-2015, 09:37 AM | #7 |
22
Rep 257
Is there a way to make sure the motor isnt toast? I took the door panel and everything off yesterday but the window would only go up 80%... I pressed the window switch to try to roll it up while pulling up on it and nothing happened... nor did I hear anything
