Starter and Alternator replacement
09-13-2015, 11:11 PM | #1 |
25
Rep 167
Hey guys,
For those of you who have replaced your original starter or alternator, how many miles you had on your cars? I'm at 170K with the original ones and deciding if I need to replace them before taking it for a long trip. Trying to prevent from being stranded. TIA! |
09-14-2015, 03:01 PM | #3 |
17309
Rep 18,733
I'm at 288K on the orginals, if that helps any.
09-14-2015, 05:57 PM | #4 |
295
Rep 2,202
I woke up that day and decided to give her a well needed wash before winter hits fuller. Starter died in the driveway. This describes the randomness of how these things could die. I was so upset that I kinda forgot to even record the mileage it happened at but my guess it was about 95k around there. Still on the original Alternator though.
Seeing that you and @Efthreeoh both have a 325 of the same year, I'm now thinking that was the good batch starters. lol
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
09-14-2015, 09:02 PM | #5 |
BMWCCA 149159
38
Rep 847
Not my E93 but my M3/4 was at 274K miles on the original alternator which was still fine. I rebuilt it. My starter was toast and did replace that so it is a good product. How many times a day do you start the engine counts a lot.
Starter is a PITA to replace... |
09-14-2015, 10:27 PM | #6 |
132
Rep 318
I replaced the starter on my son's 2007 E92 with only 70k miles, just died in the driveway
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i '19 G01 X3 | Wife's '15 F30 335i M-Sport | Son's '10 Porsche Boxster |
09-14-2015, 11:18 PM | #7 |
Is it the shoes!?
3884
Rep 5,112
Starter tends to be an unexpected failure, though it's rare in the grand scheme of things. It's an item that will just crap out unexpectedly. If you hear grinding shortly after start (YouTube starter grinding noise for a reference, text sucks at describing sound), it may mean your starter is starting to stick and you'd want to use that as a warning sign to replace it.
My advice is, if it's still working, don't worry about it. |
09-15-2015, 01:50 AM | #8 |
700
Rep 1,227
Having just had both rebuilt... both in the last month... i can say they are quality units. Both of mine were the original units from late 2006 330i.
Alternator-At around 145k miles. Mine was actually ok but i was getting a TERRIBLE rattling noise from it. Turns out one of the bearings had a crack. Electrically it was still perfect. Guy who rebuilds alternators said it was "top" quality stuff. Starter- At around 152k miles. Zero warning. I started my car, drove to work. Noticed a closer parking spot, tried to start car... i got a half crank and then nothing... had to be towed home. Next day took it out and had it rebuilt. Brushes were toast and there was a burn mark on a copper rotor part inside. Anyway rebuilder said they are of "good" quality starters. That being said if you truly have the original starter it prob wouldn't be a bad idea to have it replaced with a quality unit (not from Autozone, Oreilly, etc.) or rebuilt. The alternator i wouldn't worry too much about. |
09-15-2015, 09:28 AM | #9 |
25
Rep 167
Thanks guys! That's good to know. It speaks a lot about the quality of these parts.
Other non-bmw cars I had in the past, I had to replace the alternator at least once before 100K. |
09-15-2015, 09:35 AM | #10 |
25
Rep 167
09-15-2015, 01:40 PM | #11 |
17309
Rep 18,733
I'm hoping to hit 300K. Then I plan on a starter, alt, new tensioner and idler pulleys, and PCV. And I need a clutch sometime soon. Oh, and new engine mounts.
09-21-2015, 02:40 PM | #15 |
Beamer Mantic
82
Rep 1,191
In my case I and on my 2nd started they seem to be good for 100K miles in my case. Just replace the alternator around 238K Miles. Still have the original water pump and have one on the shelf for when the day comes.
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
