How do I band pass my Jehnert xe200 8" subs
09-13-2015, 02:29 PM | #1 |
cvsnowboarder
12
Rep 128
Hi, I have my Jehnerts LP at 200 hz on my JL Audio xd600/6v2... I've heard of people on this forum band passing them from 80 hz to 200 hz . How is this done ? My Jl audio xd600/1v2 is LP at 50 hz powering a 10" Kicker Comp RT subwoofer.
Can you give me the name of the band pass crossover that I should buy as well please? Last edited by cvsnowboarder; 09-13-2015 at 03:16 PM.. |
09-13-2015, 04:09 PM | #2 | |
223
Rep 5,120
http://www.amazon.com/s/ref=nb_sb_no...-keywords=fmod |
09-13-2015, 04:52 PM | #3 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
09-13-2015, 11:10 PM | #5 |
T667YM86
67
Rep 244
Kaigoss, can you explain how F-mods works? I have read that they are passive, so I can imagine that F-mod adapter has internal 1st order HFP and 1st order LPF, built with compact components. And we all know, that compact inductor, for example has high resistance and it's not good.
E90 325i 05MY, ZSP, Koni Sport, Eibach Pro-kit, BBS RK-II squared
09-14-2015, 10:36 AM | #6 |
300
Rep 3,969
Jehnert used to recommend an 80Hz high-pass not sure if they still do or not. Also don't know what slope. From what I have read, they are happy playing down to ~50Hz. Fmods are 12dB/oct so if you picked 80Hz, it would be down roughly 10 dB at 50Hz. 12dB down at 40Hz and 24dB down at 20Hz. I think that would be "safe". Keep in mind, the Jehnerts only have 1" voice coils and therefore cannot handle much power in the subwoofer frequency range, and need to be protected by a high pass filter.
09-14-2015, 10:38 AM | #7 | |
300
Rep 3,969
09-14-2015, 06:58 PM | #9 |
255
Rep 2,547
for the jehnerts, if you use the fmods to high pass and your amp to low pass, you would probably go with either the 50 or 70 hz high pass units. they make something called the fmod cable which will do either 50 or 70 depending on orientation, you could experiment that way.
09-15-2015, 03:37 PM | #10 | |
300
Rep 3,969
OP, don't let us recommend the crossover setting, ask the vendor you bought them from, or the manufacturer.
09-16-2015, 12:09 AM | #11 |
tends to get irritable
202
Rep 798
Agreed. Lot's of questions in various threads, have you not tried asking your vendor ? Whoever that might be ..
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
09-16-2015, 05:27 PM | #12 |
281
Rep 4,121
Speaking of vendors...wanna sell me some morels?
09-16-2015, 10:36 PM | #13 |
cvsnowboarder
12
Rep 128
I wish I could ask my vendor, but I bought the Jehnerts used. So they didn't come with any documentation or manual. So I thought I'd ask the experienced members of this here forum for advice. Particularly the Jehnert vendors on this forum since I assumed they'd have first hand knowledge on band passing/ crossover points etc. I guess I'll try to contact Jehnert directly .
09-16-2015, 10:44 PM | #14 |
202
Rep 798
I'm sure I can if that is what you really want. It's been so long since I actually sold a set of those !
09-16-2015, 10:50 PM | #15 | |
202
Rep 798
09-16-2015, 11:11 PM | #16 |
cvsnowboarder
12
Rep 128
I totally support the vendors , but when I had the chance to get the Jehnerts used for 150 bucks I'm all over it. Nobody passes up a good deal.... nobody. Just sayin'.
09-17-2015, 05:15 AM | #17 |
281
Rep 4,121
09-17-2015, 08:09 AM | #18 |
202
Rep 798
Nothing against them, we just have preferences of other things as well as the cost difference. The performance is really purely subjective though too.
09-21-2015, 03:03 AM | #19 |
103
Rep 709
Drives: BMW M4
i have bandpassed my underseats by using the lp on my amp and then feeding that low passed 180hz signal into an audiocontrol 2xs (the rarer version with a 24db slope) electronic crossover which i highpassed at 70hz - (ebay for £80). Works great, really removed the muddiness of underseats trying to play frequencies they couldn't handle. small, quick and simple to install too.
2014 M4. Non-ZCP. GTS EDC, DCT & Diff software with eibachs... gamechanger.
