Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Is It Possible To Replace Waste Gate Without Replacing Turbo?
      09-11-2015, 06:50 PM   #1
BryanDJHP
56
Drives: 2008 BMW 335XI
Is it? Mine is bad and is making a grinding noise. BMW says they need to replace the turbos and I'm only 19 and don't have that type of money. Any other small BMW shops can do it? Any tips? Also is it bad to run my car with bad waste gate?
      09-11-2015, 06:52 PM   #2
Gizm0
Gizm0's Avatar
426
Drives: 08 e92 335i 6mt
The wastegate is built into the turbo manifold... Unfortunately it cannot be replaced separately
      09-11-2015, 06:53 PM   #3
einbruch10
these are the times that try mens soul's
einbruch10's Avatar
37
Drives: 2008 335i
depending on your mileage turbos should be replaced under a BMW NA issued warranty extension. IIRC it is 8 years 80k miles for wastegate rattle/failure.
2008 monaco blue 335i sedan
STOCK
      09-11-2015, 06:54 PM   #4
BryanDJHP
56
I have 110,000 miles on my car.
What about the waste gate actuator?
      09-11-2015, 07:06 PM   #5
kdbryce
I have to return some video tapes
kdbryce's Avatar
362
Drives: e70 X5M
Didn't you just say in your other thread on the exact same subject that you have 82k miles?
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
      09-11-2015, 07:09 PM   #6
BryanDJHP
56
I do have 82k my old car has 110,000 but everytime I type in 82k auto correct me corrects it to 110,000
      09-11-2015, 07:11 PM   #7
MachWon
25
Drives: 2007 335i 6mt. JB4 + CDP's.
It is possible to replace the actuators.. but it is the same process as replacing the turbos. Still ~1k in labor.
      09-11-2015, 07:14 PM   #8
Jakester
28
Drives: F82
Mr. 5 has a thread on here about replacing just the actuator. Have you tried any adjustments to remedy the rattle already?
      09-11-2015, 07:15 PM   #9
BryanDJHP
56
I got the car yesterday I have not done anything yet. The only thing i got suggested was to put a jd4 In and apparently that makes the noise away
      09-11-2015, 07:23 PM   #10
robthewrench
266
Drives: 11 E90 335i
No trying to be too condescending here, but you are in way over your head with this car.
Yes, other shops can do it for probably 60-70% of what a dealer will charge, but it is still a large amount of money. If you go the trouble of pulling / replacing the turbos, you should replace the whole unit, not just try to fix the waste gate.
The first thing you should do is find another shop or dealer and get a 2nd opinion and estimate.
bone stock
      09-11-2015, 07:29 PM   #11
///Mposter
Macgyver
///Mposter's Avatar
208
Drives: 2007 e92 335i
You first need to check your vacuum lines or just flat out replace them. If you're 19 you probably have small hands that can reach the rear vacuum line at the rear turbo actuator. Anyway if you look up here and search for the vacuum line replacement you will see all the places the lines go . ($15)
The next test would be the boost solenoids. If you still have rattle then it might be these boost solenoids not functioning as they should. Sometimes they buzz really loudly before they go out. Anyway they are held on by a small nut or two and are really easy to replace . But they are like $85 each.
Then after you do that and if it still rattles you can adjust the wastegate actuator arm by following Mr.5's DIY .
Or if you search the forum for tischer BMW , the turbos are $599 each . But good luck in the labor.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
      09-11-2015, 07:30 PM   #12
Jakester
28
Drives: F82
Found it. Try this:
http://www.e90post.com/forums/showthread.php?t=176269
      09-11-2015, 07:33 PM   #13
bkwld
161
Drives: E90 328i N51
Hi,
Welcome to the forum. Sorry to hear some bad news. Like others have suggested, you should get your car checked out at the dealer ASAP. Either go in for oil change and ask for complimentary inspection and test drive. Tell them your concerns or simply make an appointment for possible waste gate warranty. Just make sure to keep calm and be professional. Be forthright and firm. Insist on warranty repair if their diagnosis is indeed waste gate.
Dealership can be scary just because its expensive (or like going to the doctor for your worst fear) but generally if you tell them what you want done, they won't BS too much and will try to help. At least mine does.
http://www.e90post.com/forums/showthread.php?t=729833
      09-11-2015, 08:01 PM   #14
MachWon
25
Good luck adjusting the front actuator.
      09-11-2015, 08:54 PM   #15
Bamaben
Bamaben's Avatar
183
Drives: 07 335i blk/blk/alum 6MT
You can replace just actuator without replacing turbo.
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey
mods: blackout grill, finishing rods, badges, Blacklines.
      09-11-2015, 10:39 PM   #16
sirdaft1
sirdaft1's Avatar
2203
Drives: X5 & E90 WTCC Widebody Racecar
Just throw some blue RTV on it
