Oil Filter Housing with Cooler Retrofit Question
09-11-2015, 06:57 AM | #1 |
149
Rep 460
I just purchased a 2007 335i with the sport package. It has a build date of 1/07 and does not have the factory engine oil cooler. I'm assuming due to the early build date.
Can anyone confirm if it is a "drop in" retrofit to put on a factory engine oil cooler and more importantly engine oil filter housing with the hose lines to the cooler from any N54 platform (535i) and if not at least from a 335i? I found an oil filter housing on the internet but wanted to verify the compatibility before I take the plunge. Thanks in advance. |
09-11-2015, 03:56 PM | #2 |
23
Rep 202
You should verify the interchangeability of the parts using schematics from RealOEM.com. The housing should work though on your N55, the lines I somewhat doubt.
2011 BMW 335xi (e92) - Black Sapphire Metalic, Coral Red Interior, X-Drive, iDrive, Executive Package, M-Sports, Servotronic, Glacier Silver Trim
Mods - BMW Performance Black Kidney Grilles, OEM Oil Cooler Install |
09-11-2015, 05:09 PM | #3 |
413
Rep 1,286
09-11-2015, 09:09 PM | #4 |
Head Fry Cook at McBurgertown
507
Rep 1,005
Neither the oil lines nor the cooler from a 535 are a direct fit to a 335; however, the oil filter housing is interchangeable.
09-12-2015, 01:22 PM | #6 |
BMWCCA 149159
38
Rep 847
I retro fit mine which came with no oil cooler. Just used the OFH from the cooler model and the hoses and cooler plus cover. Find a wrecked one and should be no issue. You will need a different fender inner cover unless you get that too...
09-12-2015, 07:00 PM | #7 | |
23
Rep 202
Yes, typo! The housing is the same one use on the N55 also.
As far as the new inner fender with the cutout, I plan on cutting my factory piece up and installing the grille into it. The new inner fender is $100+ so I'm going to give modifying it a try. There's already an outline in the inner fender of where the cooler opening will go along with the 3 bolt holes. I'm going to use those and the new fender grille as a guide when I modify mine.
