N54 Automatic Transmission flush
09-11-2015, 02:34 AM | #1 |
73
Rep 811
How many of you did an transmission flush after 100K miles? I was about to do mine but couple people mentioned that if you don't do it prior to 75K, dont mess with it as it causes more problem doing it after the certain mileage.
Does anyone have issues doing tranny flush after 100k? |
09-11-2015, 02:48 AM | #2 |
522
Rep 1,056
I have my appt for oil change and transmission flush this morning for my 08 E93 106k miles. I will let you know how it goes. Sometimes tranny is "slow" to engage in drive in the morning when you first start to leave. Anyone else experiencing that? Doesn't happen all the time but definitely sometimes? Not sure why that happens
2008 SGM Dinan 335i vert
2015 White Diamond GMC Yukon Denali XL |
09-11-2015, 07:58 AM | #3 | |
114
Rep 422
09-11-2015, 09:24 AM | #4 |
317
Rep 1,735
I just did mine at 99k I did the flush and filter change. I have been doing my transmission service every 30k
|instagram@underground6t9| |
09-11-2015, 10:24 AM | #5 |
73
Rep 811
Someone in my local group said that after the flush, it doesn't shift right during high rpm.
Almost as after so many miles on the tranny, the old fluid is what is holding the tranny together. Anyone have that issue? If not what fluid and package did u get? Did you do a tranny readapation? |
09-11-2015, 11:43 AM | #6 |
Beamer Mantic
82
Rep 1,191
I have had the Trans fluid changed in my wife's 06 E90 325i every 50K miles from day one. Still has the original ZF auto trans with over 250K Miles on it and it still drives and shifts well.
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
09-11-2015, 12:10 PM | #7 |
530
Rep 2,083
There is a difference between flush and a simple drain and refill.
A drain and refill might only change 1/3 of the total oil in the transmission. A full flush needs to be done by a professional with the correct tools I believe.
2013 135is DCT Carbon Black Metallic |
09-11-2015, 01:04 PM | #8 |
317
Rep 1,735
yes thats correct I only did a drain. We were able to get 90% of the oil out. It took 6.5 liters of oil to fill it.
09-11-2015, 11:09 PM | #9 |
522
Rep 1,056
Got the flush today from Classic BMW in Cleveland. Cost $339 with tax after $50 BMW service coupon I received in the mail. Car seems to shift just fine. 106k and I have never done it before. I think I'm doing the power steering flush next service and just keep changing fluids throughout as I go. Car goes to the dealer every 8-10K for service
09-12-2015, 07:46 AM | #11 |
522
Rep 1,056
No readapation that I know of. I also run the Alpina transmission flash too. Picked up the car and went. Porter who brought my car around had the car in Sport mode when he dropped it off up front with gear shift to the left so he must have known it had a little something extra special
09-12-2015, 10:36 AM | #12 |
228
Rep 1,045
Everyone needs to be careful to NOT make 'drain' and 'flush' to be the same task!!!
'Drain' changes fluid, it is what BMW recommends at 100K intervals, and ZF recommends for the 335i engine A/T transmission at 60K intervals. 'Flush' is NOT recommended! Flush vs. Change A flush uses a professional grade machine to completely flush all the transmission fluid from your vehicle and to remove some grime and contaminants. This process runs a special solution through the lines until they come out completely clean and then fills up the system with new fluid. A change on the other hand simply drains it using natural gravitational forces. Not all the fluid in the system is drained using this method and it does not flush out contaminants. ZF says to put in a new pan with integrated filter in the ZF A/T for BMW. |
09-12-2015, 01:40 PM | #13 |
BMWCCA 149159
38
Rep 847
It isn't recommended to flush a high mileage transmission. Reason being the flush may well disturb steels or clutch material doing no harm and get stuck in a check ball causing the transmission to not operate correctly.
I do only drain and refill except when there are sufficient miles to do a pan change. I do this every 40K miles or so which based on the analysis done by Blackstone was too early. I would not be worried about getting a transmission flush at 50K miles as recommended by ZF in their PDF. I have posted that PDF elsewhere and I follow what the manufacture of the transmission recommended NOT what BMW recommended which used to tell us it was "lifetime" fluid. Your transmission your call but I would be extremely uncomfortable doing a flush at 100K miles given I have seen too many transmission start to slip a few weeks after the change. |
09-12-2015, 04:37 PM | #14 |
141
Rep 426
I flushed my original transmission fluid in my old Taurus SHO with 110,000. The Trans died about a month later. It started shifting REALLY hard soon after the flush and got progressively worse. Coincidental? Maybe. However I've started doing drains on higher mileage cars from then on.
09-12-2015, 10:22 PM | #15 |
73
Rep 811
That's what I was worry about too. So in my case of 100k. Just drain it and don't worry about the oil pan?
Thanks for the info. It was the response that I was looking for. What is the ZF? |
09-13-2015, 03:53 AM | #16 |
125
Rep 445
ZF is the manufacturer of our 335i transmissions, the 328i transmissions are GM
2008 E92 335i-MHD FBO-6MT Conversion- CIC I-drive Retrofit
09-13-2015, 04:23 AM | #17 |
73
Rep 811
Cool. Thanks for the info.
When doing a simple drain, what kind of oil would you suggest? And is the oil pan and filter necessary to change out at my mileage? (100K) |
09-13-2015, 04:32 AM | #18 |
DIE ANTWOORD
68
Rep 640
No surprise due to the random stuff some fill in instead of the ZF recommendet fluid
King of the road says you move to slow
09-26-2015, 08:47 PM | #19 | |
681
Rep 3,696
09-27-2015, 09:18 AM | #20 |
20
Rep 352
Harry, I did mine as you know and it works great. It slipped out of gear at the drag strip and now holds about 70hp more and no problems at all.
I ordered the Pan Fluid and mechatronic sleeve from ESC tranny kit. |
09-27-2015, 10:59 AM | #21 |
149
Rep 460
I just changed out the filter (pan) and did a drain and fill. I'm at 78K miles. The fluid was pretty dark. Also, when I pulled the pan I was surprised it still had a lot of fluid in it. I replaced about 6.5 quarts total. All in all it was a pretty simple job. Just a bit messy.
10-15-2015, 12:04 AM | #22 |
73
Rep 811
Does the ECS tuning kit include the mechatronic sleeve? Or it called "M18 transmission fill plug" included in the kit?
ECS tuning assembled the kit with VAICO transmission fluid. Is it recommended? For the pan and filter, should I go with ZF or Vaico? |
