09-10-2015, 12:02 PM | #1 |
47
Rep 399
Wheels spacers for f34?
Hello just picked up a f34 sport line and looking to buy wheels spacers, does f30 spacers fit the f34? And did anyone install them and what size should I get for a 18x8 square set up. Thanks!
European delivery 9-19-2012
09-10-2015, 11:45 PM | #2 |
507
Rep 1,239
Maybe 12 in the front and 17 in the rear sounds great from H&R, maybe someone else can chime in
09-22-2015, 04:26 PM | #3 |
Yr1OfD1
109
Rep 900
subscribing on this thread. im interested as well
2015 328i Gran Turismo M Sport
2013 328i XDrive Sedan M Sport 2011 X5 xDrive50i 2009 X5 xDrive 30i 2008 135i Coupe |
09-22-2015, 09:26 PM | #4 |
8313
Rep 16,195
I advise against them. One of the first accessories I got was mud flaps. Before they arrived the tires would throw quite a bit of road crap onto the front doors, sills and rear quarter panels. Even after putting them on there's still more than I care for. Pushing the wheels further out will only make matters worse. They don't do all that much for handling, and where cosmetics are concerned getting your paint job damaged from road sand and salt isn't going to improve the looks of the car.
09-24-2015, 04:08 PM | #5 |
37
Rep 71
Spacers
I have been running spacers on my last two BMW`s. On my E 91 M Sport I had the original 18" wheels with 15 mm spacers in the rear and drove with them for 125 000 km without any trouble. Now I have a F 31 M Sport and I have been running 10 mm spacers front and rear for 95 000 km on the original 19" wheels. The 5th of october I will be picking up my F 34 M Sport also with 19" wheels, my plan is to try the 10 mm spacers from the F 31 on my F 34.
2015 320 Xd GT F34 M Sport 2012 320 d F31 M Sport 2009 318 d E91 M Sport |
01-26-2016, 02:46 PM | #7 |
96
Rep 95
Spacer size update.
I have a 2015 335i xDrive GT with 19" BMW M Performance Double Spoke 598M Rims, Pirelli P Zero Run-flat Tires 225/45 R19 92W (Front) 255/40 R19 96W (Rear)
I installed BMS 12mm spacers front and 15mm back. So far no rubbing but its close in the inner wheel well in the front at full turn. Not close to the body or fenders. http://www.burgertuning.com/BMW_wheel_spacers.html |
03-17-2016, 10:19 AM | #10 |
Rep 9
Installing 403m wheels on F34
Hey all,
I am new to this thread and also new to modifying cars. For 2 years I have been driving my GT 320d on long distances, approx 1,500km/month and have plans to change to new tires. With that said, I am looking into purchasing a new wheel to change together with the tires. My personal favorite is the 403m 19" wheels, but i am not sure it will fit the GT due to differences in the offset. Current 397 rims: Front and back Tire: 225/50 R18 Rim: 8Jx18 ET34 New 403m rims: Front Tire: 225/40 R19 Rim: 8Jx19 ET36 Back Tire: 255/35 R19 Rim: 8.5Jx19 ET47 For someone who is very inexperienced, can someone help explain if it would be possible to install the 403m to my F34? Thanks a lot! Yang |
08-01-2018, 07:04 PM | #11 |
Master Chief
54
Rep 228
Anyone intall 20mm > on the rear? Looking to do 12mm front and 20mm rear. BMS look like the brand to roll with. I’m currently running all OEM in regards to tires and suspension.
225/50/18 et34 all around |
01-19-2019, 07:29 PM | #12 |
Master Chief
54
Rep 228
Ended up putting macht schnell wheel spacers.
Running 15s upfront and 20s in the rear. Haven’t notice any rubbing yet and have been driving them for a couple months Last edited by BNTLY; 01-19-2019 at 07:39 PM.. |
06-10-2023, 03:24 AM | #13 |
46
Rep 67
Any other advice on spacers? I was thinking about adding them before getting some summer rubber for a track day now that the suspension bits are lined up.
06-12-2023, 07:35 AM | #14 |
295
Rep 487
I run 10mm at the front and 12.5mm in the rear with OEM 598ms in staggered set-up. 15 mm at the back produces rubbing of the wheel liner by wheel outer wall when car is under load.
OEM staggered set-up specs (without spacers) are: 19x8 ET30 w/ 225/45 front and 19x9 ET42 w/ 255/40 rear.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
08-17-2023, 02:06 PM | #15 | |
39
Rep 79
Once I get around to mounting my staggered M-sport wheels (18x8, 18x8.5), the spacer orientation may change.
2017 BMW 320i GT (F34). M-sport brake/wheels upgrade. Stage-1 tune, Kies Motorsport charge pipe, Dinan coils, K&N filter. KW v1 coilover kit.
