Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Help needed with couple of DSC errors
      09-10-2015, 10:31 AM   #1
freak1
Drives: 2012 528i Sports Package
i have been getting this error since a while now on my '06 330i E90. I have Carley app and wifi obd scanner. Everytime I scan the car the following two error pops up. Even after I delete it comes right back. Btw, I have no lights on dashbord. Cruise works on and off. The codes are:
005DCC- Pressure sensor is defective right
005DBC- Pressure sensor is defective left rear
I also followed $0.02 steering angle fix and resoldered the board and cleaned the disk, still looks like no luck.
Any help is greatly appreciated.
Thank you all
      09-13-2015, 11:26 PM   #2
freak1
Bump
      09-14-2015, 05:32 AM   #3
Efthreeoh
17309
Drives: The E90 + Z4 Coupe & Z3 R'ster
Not familiar with your brand of software, but regardless, an OBDII scan tool would not pick up on DSC errors anyway. If you are having stability and traction control issues it is most likely a wheel speed sensor, which I think is what your software is trying to tell you. It is probably mis-translating "pressure" with "pulse" Some software packages call the wheel speed sensor a "pulse sensor", because the sensor generates a pulse message when it counts the wheel speed.
Replace both sensors and see what happens.
      09-14-2015, 09:19 AM   #4
freak1
Thanks for the insight. I'll try the solution and update with the results.
Thanks again
      10-25-2015, 11:36 PM   #5
freak1
I replaced both the sensors and still same issue. Replaced battery with AGM and coded and registered. Scanned again and still same error. Here's the pic.
Any insight is highly appreciated
Are these readings normal?
Above are the numbers without pressing brake pedal and following are the numbers when I press brake pedal.
Couple of pics with error-
Thank you
      10-27-2015, 12:17 AM   #6
freak1
Bump
