How would you flush oil out?
09-09-2015, 03:46 PM | #1 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
I did a coolant flush (DIY) and noticed a little oil in the reservoir tank. I know I had a OFHG leak before but that was repaired. Is it safe to say that some oil remained even after my flush? I'm thinking of flush it again because I only used BMW coolant and distilled water mixed 50/50 (point being it was cheap).
My real question is, how can I effectively remove the remnants of oil? Any chemicals? Will pouring distilled water through the reservoir/radiator clean it out a bit more? Thanks!
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
09-09-2015, 06:34 PM | #2 |
449
Rep 1,327
Does the oil just rise to the top? Can I just skim the top layer from the reservoir? Thanks
09-10-2015, 10:45 AM | #3 |
449
Rep 1,327
Bump
09-11-2015, 03:59 PM | #4 |
23
Rep 202
Skim what you can see off the top, and see if more comes back. The next step after that if you're still getting some and you're concerned would be to empty out the cooling system again, flush it with distilled water and maybe a cleaner, and refill once again once cleaned.
2011 BMW 335xi (e92) - Black Sapphire Metalic, Coral Red Interior, X-Drive, iDrive, Executive Package, M-Sports, Servotronic, Glacier Silver Trim
Mods - BMW Performance Black Kidney Grilles, OEM Oil Cooler Install |
09-12-2015, 12:43 AM | #6 | ||
449
Rep 1,327
Thanks!
09-12-2015, 05:17 AM | #7 |
17309
Rep 18,733
Oil and water do not mix, so just trying to flush the system with water will not remove the oil. If there is oil in the cooling system you need to use a detergent in the system with water. The detergent breaks down the surface tension of the water molecule and allows the oil to combine with it and that will rid the system of oil contamination.
09-12-2015, 07:07 PM | #8 |
23
Rep 202
There are a few cooling system or radiator cleaners out there that you can use, Prestone makes one. I haven't used a cleaner made for that specifically, but I have used dishwasher soap in the past on my winter beater with some success. I'd suggest using the stuff specifically made for cooling systems though, especially since what you're trying to get out is fairly fresh and just oil (not caked on everything). You can use household water for the flush a few times over, then follow that up with at least one fill and drain of distilled, maybe two if you want to be sure that any water left behind is as close as possible to the quality of distilled water. Once the distilled is out of the system fill it back up with new BMW coolant and you should be good to go.
As far as mixing up coolant, I usually try not to waste the distilled (because I'm cheap like that). It depends I guess how much coolant you have and the capacity of your distilled water bottles. Here in Canada I get 4L distilled water bottles and coolant usually comes in 4L jugs. I would poor half of the distilled bottle in the car followed by half of the coolant. What's left gets mixed together in the bottles. You can shake it up a bit if you want, but it usually blends itself pretty good. The stuff that went into the car unmixed will mix itself fairly quickly with one heat cycle. This method ensures you end up with a 50/50 mix.
09-13-2015, 02:04 AM | #9 | ||
449
Rep 1,327
09-14-2015, 01:49 PM | #11 |
449
Rep 1,327
It likely won't harm anything in the short term but it could contribute to plastic parts wearing out faster. At least, that's what I've read on E90post.
