Oil leak worse after OFHG & VCG replacement
09-09-2015, 12:12 PM | #1 |
393
Rep 1,371
I got my VCG and OFHG replaced about a month ago by a local indy shop. The leak wasn't very noticeable on my garage floor before I took it in, but there were a few spots.
It looks like the car has been leaking worse since I got it back as there are now much larger spots on my garage floor. And last week (which was about 4 weeks after the OFHG & VCG were replaced) my oil indicator level was halfway between MIN and MAX. Does it sound like the repair wasn't done correctly or is just coincidence that this leak started occurring after the repair was done? Should the shop offer to take a look at their work and make sure it was done correctly? |
09-09-2015, 12:15 PM | #2 |
Rep 44
Did the shop diagnose the leak coming from the VCG and OFHG or did you tell them to replace them? If the shop told you thats where it was leaking from bring it back to them and tell them that was not the source of the leak and tell them to find and fix the leak(on their dime). If you told them what to replace then bring it back and tell them to find and fix the leak(On your dime)
09-09-2015, 12:34 PM | #3 | |
393
Rep 1,371
After they replaced them, they said that they did need to be replaced and I was right. |
09-09-2015, 12:48 PM | #4 |
711
Rep 3,251
It is possible that they pinched the VCG while installed them. That thing takes some patience to get it seated right, and will leak if they rush the job.
Honestly, for this type of work, do it yourself if you want it done right. All you need is some basic mechanic tools and a free day during the weekend.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
09-09-2015, 04:52 PM | #5 | |
393
Rep 1,371
09-09-2015, 04:58 PM | #6 |
12
Rep 94
The valve cover themselves tend to crack with miles and age. Its a good chance the cover cracked during torquing during installation or was already cracked and thats why you still have a leak.
09-09-2015, 06:20 PM | #7 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
I'm with you. I also believe the valve cover was likely not replaced and probably has a crack in it.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
09-09-2015, 10:09 PM | #9 |
56
Rep 221
It could definitely be your oil pan gasket. Mine has been leaking horribly. Luckily I found a shop to do it for only $350, which was a steal. So I had them put new motor mounts on as well
09-09-2015, 11:08 PM | #10 | |
886
Rep 2,720
My car's VCG got pinched by the shop who did it and it kept leaking. The mechanic felt bad about it and of course they fixed it by replacing it with another new VCG. This seems to be the issue in your case. |
09-10-2015, 07:51 AM | #12 |
107
Rep 485
Could be the oil pan gasket. The VCG, OFHG, and Oil Pan gasket tend to fail around the same time. Oil pan will tend to leak at the engine/bell housing interface. It can look like a rear main seal has failed but more often it's the oil pan gasket.
09-10-2015, 10:39 PM | #13 |
Rep 4
+1 on this, I replaced every oil related gasket, not believing a oil pan gasket could leak and finally replaced it and no more oil leaks, and all gaskets failed about the same time.(80Kmi) Cost around $4K at a indy b4 I was oil leak free. I got a break at $700. for the oil pan gasket, which is a nasty job.
10-08-2015, 07:44 AM | #14 |
393
Rep 1,371
So I took the car back to the shop and they replaced the VCG again, free of charge. They said a piece of it was folded over/pinched on the first install. After one day, I haven't noticed any oil leaking so I think it's leak free now - at least I hope.
10-08-2015, 09:59 AM | #15 |
164
Rep 598
Glad you got it fixed. For future reference, I believe the valve cover bolts are aluminum and prone to breakage. It's recommended that the bolts be changed out as well and accurately torqued to spec. An over-torqued bolt can break can cause a leak.
10-08-2015, 10:04 AM | #16 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Which indy did you go to? Feel free to PM me if you don't feel comfortable telling everyone.
10-08-2015, 10:50 AM | #17 |
1645
Rep 2,494
That's only on the early N52's. OP has an N54 and thus, steel bolts - only needs replacement if there is a problem with the old ones.
10-15-2015, 07:36 AM | #18 |
Maximus Decimus Meridius
1130
Rep 4,584
Nice, so when I do my valve cover this weekend I can reuse the old bolts with no issues..?? Seems many replace them, maybe they are unaware that they're steel..
F30 335i Melbourne Red Metallic M-Sport Package |
10-15-2015, 07:50 AM | #19 |
1645
Rep 2,494
I mean, you'll need to inspect your bolts and make that decision yourself. It certainly wouldn't hurt to replace them, but it's not a requirement like it is for people with the aluminum bolts.
10-15-2015, 08:52 AM | #20 |
31
Rep 228
You can definitely reuse them if they are not damaged. Just make sure the threads are not fouled with engine oil before reinstalling, same with the holes, as this can easily result in over-torquing on re-installation, leading to more issues.
10-15-2015, 09:18 AM | #21 |
1130
Rep 4,584
True, thanks for the tip... I'm now on the fence of replacing other gaskets while I'm in there.. Oil Cooler and such...
10-15-2015, 09:35 AM | #22 |
31
Rep 228
Well I have an N52 but I'll say this, I did my OFHG first. It caused a noticeable increase in the leaking I had in the VCG immediately. I also suspect that the VCG leak was responsible, at least in part, for the bank 2 upstream O2 sensor failing, although my washer fluid filler neck also had a pinhole leak so I can't know which one may have done that sensor in for sure or if both played a part. After replacing the VCG (and the valve cover itself), my oil pan gasket is now leaking noticeably worse. Your results may vary...I'd say do as much as you have the time and the means to do at once though.
