most troublesome flat tire ever
09-08-2015, 05:42 PM | #1 |
78
Rep 375
Saturday night around midnight I hit a pothole in the middle of the highway at 70mph and it ripped a hole about 2" wide in the sidewall of my front right tire. So I think ok, whatever, I'll just change it with the spare from my mom's 2002 330i. Called her up and got her to drive out to meet me, take my wheel off and tried to put her 17" spare on and found out it wouldn't fit over my brakes. So I had to put my flat tire back on and call a tow truck.
Fast forward to Monday, I take off the wheel from my car and get ready to go take it to the tire shop, and then remember it was Labor day so everything was closed. Ended up sticking a cinder block under the jack point and just left it like that overnight. This morning I call up the tire place to get them to send 2 tires from their warehouse so I can switch both front tires since they're getting kinda old anyway. I take the single wheel that's already off my car to them so they can install the tire, and take it back home to put on my car. Then I drive my car back to the shop so they can install the other tire. About 10 minutes after they pull my car into the bay, they come and ask me where my wheel lock thing is. Then I thought o crap, I left it in the lug nut after I put the wheel on and just drove off like that, so it's somewhere on the side of the road between my house and the shop. So now I have to wait until Thursday morning because the dealer doesn't have them in stock and they'll have to order it. I have one new tire and one old tire on my fronts, and a missing wheel lock key. Just wanted to rant. |
09-08-2015, 08:11 PM | #2 | |
681
Rep 3,696
2) they just hammer a larger socket over the keyed lug and use that to force the keyed lug to turn. i don't understand why stock rims come with wheel locks... who steals stock rims any more? once u get the new keyed lug... remove the other keyed lugs and just go back to a normal lug so you don't have that problem ever |
09-08-2015, 08:51 PM | #3 | |
17309
Rep 18,733
09-08-2015, 10:44 PM | #4 |
681
Rep 3,696
09-09-2015, 05:04 AM | #5 |
17309
Rep 18,733
You just reminded me I need to order some wheel locks for the Z4...
09-09-2015, 06:48 AM | #6 |
886
Rep 2,720
Ask for some forum member help in ur local forums...
09-09-2015, 07:53 AM | #7 |
3973
Rep 7,215
similar thing happened to me earlier this year, only it was a rear tire, and I tried to swap it off my wife's 325xi. 16" wheels, not even close to fitting over the brakes.. doh!
I hate the wheel locks, I really need to order 8 more regular lugs and throw them in the trash.. maybe if you had some expensive aftermarket wheels, but stock ones? Also with the way the factory wheels are designed I don't think you can hammer a socket over the head of the lug. the hole is too small for that. I really doubt any tire shop is going to drill out a bolt for you either, unless something is really fucked up; I've been turned away for simple stuff like having a stud kit instead of lug bolts. so basically the wheel locks suck and relying on only run flat tires is annoying. I want a full sized spare like a real BMW should.. |
09-09-2015, 01:29 PM | #9 | |
681
Rep 3,696
09-09-2015, 01:33 PM | #10 |
3973
Rep 7,215
looking at the stock wheels, I don't know how you could cram a socket over the head of the lock bolt without damaging the wheel. hell, on my wife's car I can barely get the stupid lock off the bolt because I can't get my fingers in there to grab it..
