2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB 1st Oil Change Issue
      09-07-2015, 01:23 PM   #1
1LegitM235i
1L
156
Drives: 2015 Glacier Silver M235i
Bought my oil change kit from getBMWparts and as I was pouring the first three liters, my son noticed a different type of oil on the other four. It was 5W30, Longlife-01/gasoline/diesel that I first poured. The other four is 5W30, Longlife-04/Diesel. So I am stuck at this point because I do not have the right ones. I wished I had noticed this first thing before removing the old oil.
Does anyone have any recommendation for me? If "getBMWparts" was available when I called them, I would have some answer. Do you think it will be safe to use the "04/Diesel"? Any suggestions is greatly appreciated! Thanks!
2015 Glacier Silver M235i/6MT
MP Front Splitter//MP CF Short Shifter//MP CF E-brake//MP LSD//Cold Weather package//Driver Assistance package//Oyster Dakota leather//Aluminum Hexagon trim//ECS Tuning Wheel Spacers//AutoPlus Rear Diffuser//HUD//Rexing DashCam//AutoID M Mirror Caps
      09-07-2015, 02:03 PM   #2
overcoil
3069
Drives: M235i 6spd
1Legit, I'm not at my home where I have the BMW branded oil bottles of both the Castrol and the new updated Shell oil for our 235. When I get home later I can view the bottles and snap a picture so you know what the bottles Frm the dealership look like.
Believe the part # should be 83212365946, but I need to double check.
      09-07-2015, 02:14 PM   #3
1LegitM235i
1L
156
Hey Scott, I know the first three of my oil was the correct ones, but since I don't have access to BMW's parts department near me. Is Castrol 5W30 LL-01 available at nearby auto shop? I'm a bit disappointed this was overlooked by the seller.
      09-07-2015, 02:35 PM   #4
overcoil
3069
Drives: M235i 6spd
I would go to the Shell Pennzoil web site and use their OIL SELECTOR to find an oil.
Or the Castrol site and their OIL SELECTOR.
http://lubematch.pennzoil.com/recomm...e=18&brand=121
      09-08-2015, 05:26 PM   #5
eclipes
47
Drives: 228i Msport
Anyone use 0w40 from castrol?
      09-08-2015, 05:50 PM   #6
Ian_Mark
14
Drives: '14 228i MSport
2014 BMW 228i  [0.00]
2005 Subaru Sti  [0.00]
i used 0w40 European blend on my Subaru. but here ive used 0w40 European blend by mobile 1
      09-08-2015, 09:05 PM   #7
eclipes
47
Drives: 228i Msport
Great, im gonna try it on my next oil change to see how it feels.
      09-08-2015, 09:07 PM   #8
Pparana
463
Drives: 2015 m235i
I do, but I change my oil a lot, every 2-3 track days, plus I have meth injection. So I prob do 5-8 changes a year
      09-11-2015, 02:12 PM   #9
eclipes
47
Drives: 228i Msport
How does it feel? Do you like this oil?
      09-11-2015, 06:16 PM   #10
Pparana
463
Drives: 2015 m235i
If your wot alot (track), you will see a higher engine oil temp, 0W-40 will operate closer to design specs than 5-30. Feels the same, nothing noticeable. no fuel consumption change.
Also better suited for warm climates, so 5w30 for you.
I grew up in Buffalo, so I know Toronto, you can run the 0w40 prob. 4-6 months a year if you wanted to.
      10-02-2015, 11:56 AM   #11
Iron Man
Iron Man's Avatar
189
Drives: N/A
LL-04 oil is a low/mid-SAPS oil and should really be used in areas with extremely high quality gasoline (Germany, Switzerland, etc.) and not the USA. It has a lower TBN, which means it will not protect as long with the poor gasoline we have in the US.
LL-01 oil is a High SAPS oil, with higher TBN, so it protects longer. If you change your oil more frequently than say the suggested 10,000 mile interval, like at 5,000 miles, you should be okay. However, how quickly the TBN breaks down depends greatly on your driving habits.
In your case, you could use it, but just need to leave this blend in for a shorter typical time period.
Appreciate 2
jpnh1423.50
      10-05-2015, 02:11 PM   #12
1LegitM235i
1L
156
Thanks Iron Man.
      11-18-2015, 09:53 PM   #13
eclipes
47
Drives: 228i Msport
How many litres required for the oil change?
      11-18-2015, 10:39 PM   #14
overcoil
3069
Drives: M235i 6spd
I think 6.5 liters - but double check.
      11-19-2015, 11:32 AM   #15
Zooks527
310
Drives: 2015 M235xi / 2005 Tacoma 4x4
The sump is 6.5 liters / 6.9 quarts dry.
Buy 7 liters. Put 6 in at the time of the change. With residual holdup in the system, you should find the indicator at either 3/4 or Max after doing so. Put the 7th liter in the trunk.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi
      11-30-2015, 07:42 PM   #16
eclipes
47
Drives: 228i Msport
Just did an oil change today. Mechanic says the 6 cyclinder takes about 6 litres. The N20 takes 5 litres. Just for info if you're changing your own oil.
Tags
first oil change, oil type issue
Search this Thread:
Advanced Search
2addicts
