Use 2 chans of a 4-chan amp
09-05-2015, 02:34 PM | #1 |
Rep 19
I'm still googling for the definitive answer, but I'd like to ask the experts here:
Is it safe to use only 2 channels of a 4-channel amp? Backstory: I have a sub and a 4-chan amp already from a previous install. I know I can get a mono or 2-chan amp to drive the sub but I really don't want to spend if I don't have to? I did a test-run with this setup and observed that the 4-chan amp was much warmer than the main amp from which I was tapping into RCA outputs, with the sensitivity turned way down. I'm concerned with the heat from the 4-chan amp. I drove around the block listening to music for about 10 minutes and the 4-chan amp was just a bit too warm... Thanks in advance for any advice! |
09-05-2015, 03:06 PM | #2 |
729
Rep 1,815
Depends on the amp. If you are able to bridge 2 channels to each speaker it makes it easier and if the amp is capable of the speaker impedance you will normally make more power.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
09-05-2015, 03:13 PM | #3 |
36
Rep 407
If you connect 4 speakers to 2 channels, the output from the amp has to drive all speakers. Do read about serial and parallel conmections. Neither is really good for the amp. I would just pick up a small mono amp for the sub. You dont want to take any risks with heat/fire hazard on such an expensive car
09-05-2015, 04:13 PM | #4 |
Rep 19
To be clear: I bridged two channels to drive the sub. The other two channels I've left empty (both the speakers output and RCAs input). The sensitivity of the empty channel is turned all the way to minimum. The sensitivity of the bridged channels driving the sub is about 1/8th of total (so not a lot).
Yet it ran warm. That's my worry and question: is the warmness normal or should it run "cooler" because only two of its four channels are being outputed (spelling?). |
09-05-2015, 06:44 PM | #5 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
09-06-2015, 05:38 AM | #6 |
Rep 19
Amp is xd400/4. Sub and enclosure are JL Audio. I will have to remove the sub from its enclosure to learn the impedance/model of the sub, unless there's a way of discovering the impedance without disassembling the sub from enclosure.
09-06-2015, 06:21 AM | #7 |
Rep 19
Sub+enclosure is CS112RG-W1v2: One 12W1v2-4, sealed enclosure, rear-firing, gray carpet finish, 4 Ω final impedance, steel mesh grille included.
Amp specs for Bridged @ 4Ω: 200 W RMS x 2 So it seems the sub and amp both show 4ohms as configured. So I'm guessing and assuming that the warmth of the amp is sorta normal |
09-06-2015, 08:22 AM | #8 | |||
729
Rep 1,815
I do agree that he needs to learn about series and parallel configs but because of impedance loads as I mentioned in my first post. Quote:
The warmth is normal but if it is HOT, your gains may be set too high. An after thought, is this a hifi or logic 7 system? You could use the extra channels to power the underseat woofers.
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car Last edited by david in germany; 09-06-2015 at 08:32 AM.. |
09-06-2015, 08:48 AM | #10 | |
729
Rep 1,815
By the way, if you are into car audio and may do other installs, look into a SMD dd-1 a great tool to use setting gains.
09-08-2015, 09:00 AM | #11 | |
2134
Rep 3,554
Yes you can run 2 out of 4 channels with no issue.
Yes you can run your 4ohm sub bridged on the 2 channels. Yes you need to properly set your gains. Amps do get warm, but clipping will make it hot, fast; and will ruin your sub/amp. Quote:
Also, you can check the impedance of the sub by measuring it at the sub leads. No need to remove from box as long as you know how you wired it. |
09-08-2015, 09:21 AM | #12 | |
36
Rep 407
I had misunderstood that he was running multiple speakers using a single channel. Thats why I was suggesting him to not do that based on my reading. |
09-08-2015, 09:24 AM | #13 |
2134
Rep 3,554
running multiple speakers in series and/or parallel on a single channel does not hurt amps either.
