09-04-2015, 02:41 PM | #1 |
649
Rep 4,323
Enzo 400R+ tune review: A Lady in the street and a Freak on the Track
It takes a lot to wow me - and if some of you have followed my build since 2012 (OG F30 335i), you'll know I'm never one to shy away from the avant garde modifications: was the first to do the M Performance suspension (what a disaster), first to do the PPK on a 2012 build (with a new DME to boot), and probably a few other experiments I'm forgetting to list
Current pre-Enzo build: M Performance PPK, LSD; Dinan CAI; ER IC and CP. Editor's note: I have a weird fuel injector/fuel pump issue. List of things to do in Enzo's Garage: ER DP (with a 200 cell cat, because I'm a tree hugger at heart) Enzo Tune Time in: 8am Time out: 12pm (I was second in line, it took Frank 2 hours to do my car, which is unfreakinbelievably fast for WHAT he had to do) Initial impression: WTF.I was floored at how different everything was performance wise...the throttle tip in was more aggressive with the PPK, but the tune took it to another level in comfort, and Sport mode was simply ear to ear grinning. Full throttle is scary fast - if I take it to a drag strip, I'm sure I'll be in the 12's in the 1/4. At Lime Rock, I'm assuming several second shaved off because I usually only hit 118-121mph on the back straight - I'm sure I'll hit it earlier, and possibly hit my speed limiter with this tune! The power is progressive and linear, and some mild lag that I have is probably due to my IC, not the tune. The new DP certainly helped cure MOST of that, but don't kid yourself, this isn't an M3 twin turbo with water cooled IC Now for some pictures...how the f do you take pictures of a tune? LOL, here are a few snaps from the shop, and some swag I acquired, Conclusion: RUN to go and get this. Enzo went to Germany to learn how to do these tunes SPECIFIC to our cars, and has dyno/road tested them. Most of the other tunes that are now being flashed are off the shelf ones from the base tune acquired from Germany...of course, each tuner will have different outcomes/safety parameters/AFR's, but I'll have to say that I'm ecstatic with the outcomes. The free install is also a huge plus - pulling the ECU isn't easy, since it sits under the manifold and there is a lot of unclipping/unscrewing involved. The shop itself is one of the nicest I've been to...you feel like a mere mortal amongst car gods, with a lambo and mclaren on either side of your car (not to mention an M4 that was just pulled off the stand). The italian espresso and comfortable/great lounge area made the wait go by fast - Frank was a a ninja with his impact gun, and managed to work with the fabrication team to create a strong clamp between my DP and the stock exhaust (the original one was rusted beyond belief, warning to those in the Northeast!) And that's why it's kind of nice being in a shop that can fabricate/weld ON the spot.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
09-04-2015, 04:26 PM | #2 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
FBO-PS1 and stuff
09-04-2015, 07:49 PM | #4 | ||
649
Rep 4,323
09-05-2015, 10:17 AM | #7 | |
649
Rep 4,323
09-06-2015, 12:14 AM | #8 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
Oh mine is already done, getting a BEF in a few weeks from Eurocharged. Their first BEF is how i hit 560whp/540wtq. Now that I have colder plugs, new DV+ and tires, and E60 mix instead of 93, i should be pretty close to 600, hopefully
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| Last edited by obriennathaniel; 09-07-2015 at 06:00 AM.. |
09-06-2015, 06:04 PM | #10 | |||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
09-09-2015, 10:16 AM | #11 |
181
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
Can't wait to get my tune done. Just waiting on my DP to arrive so I can install it before the tune. Not sure if you mentioned but do you have a 6 speed or the 8 speed auto? I have a 6 speed and I wonder if I will have issues with the added power?
09-09-2015, 10:42 PM | #12 | |
649
Rep 4,323
09-15-2015, 11:46 AM | #14 |
21
Rep 166
any videos?
M Sport: ~JB4 STG 2 ~ FF Wires ~ AFE 5R Intake - Catless ER DP ~Tints ~ CF Interior Trim ~ CF Diffuser ~ CF Trunk Spoiler ~ CF Mirrors
09-11-2016, 10:41 AM | #15 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Not sure how I missed this last year, but I happened to be researching flash tunes, and stumbled upon this thread. Looks like you've been modding hard since we got together to with the 335s to check suspension ride quality, LSD, etc...nice work!
From a quick look at the dyno curves, I think I like the EnzoTune better than Dinan. I think I'll give them a call to talk about options... How are you liking the tune a year later?
Ahead of the curve for specF30
09-11-2016, 12:26 PM | #16 | |
649
Rep 4,323
Tune if stock is fine, now that I've upgraded to a larger turbo, I'm not getting the support from them I need.
